9360\error code 513
SOURCE: jvm error 513 lost all programs
how do i get this jum error 102 off my phone so i can use it
SOURCE: how do i reload software 513 for my blackberry storm.
What you need to try to do is reinstall the blackberry OS (operating system) on your device.
Assuming you have verizon
First install Blackberry desktop manager it should be in the CD that came with the phone.
If you can't find it download it
https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=5E695511C1F9656B8E3E63DAB060F469
Then download the OS software for your phone http://vzw.smithmicro.com/blackberry/download.aspx?ct=personal"
Install it
Connect your phone to your computer and start Desktop manager
Click on application loader, on update software click start, click ok on USB pin selection.
when you get to the device backup and restore options, click settings
and make sure backup options box is unchecked and device data boxes are
both checked, click ok, click next, skip the email signup stuffs,and
finish.
After the software is installed the phone should boot back up
SOURCE: my phone shows reload software 513 !
Full flash is required for your phone.you can flash it using desktop manager and you can download firmware here.http://na.blackberry.com/eng/support/downloads/download_sites.jsp
Or you can contact w/ me if you need some help....,,my YM:[email protected]
SOURCE: how to reload software 513?
I have a blackberry curve that drove me crazy because the application loader didnt work with mine either but here is what I tried and it worked for mine so hopefully it will work for yours. First, go to the blackberry.com website and click on software. Then click on device software. Select the version that is compatible with your phone. Be sure that your phone is connected to the computer with the USB cord that is came with. Then click download and follow the instructions from there. This should reload the software on your phone.
SOURCE: reload software 513 error
After typing an incorrect password ten times and restarting the BlackBerry smartphone, the following error appears:JVM 513
All of the data and applications on the BlackBerry smartphone have been deleted and The BlackBerry® Device Software must be reloaded on to the BlackBerry smartphone (Due to the Java Virtual Machine (JVM) error, the BlackBerry smartphone will not show a Connected state in the BlackBerry® Desktop Manager. Proceed to reload the BlackBerry Device Software using the Application Loader)
To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.5 and 4.6, perform the following steps:
1) Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
2) Double-click Application Loader.
3) Click Add/Remove Applications.
4) Type your BlackBerry smartphone password and click OK.
5) Select the check boxes next to the names of the applications you want to load.
6) Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications.
7) Click OK.
8) Click Next > Finish
9) When the process has completed, the message The loading operation was successful will appear. Click Main Menu to return to BlackBerry Desktop Manager.
After the maximum number of password entry attempts is exceeded by
supplying incorrect passwords, and the BlackBerry smartphone is restarted, the
It says Reload Software: 513
smartphone
Steps how to reload can be seen in below website
http://www.blackberry.com/btsc/search.do?cmd=displayKC&docType=kc&externalId=KB11320
Thank You
