Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
SOURCE: No picture no sound
Hi!
It sounds like you have a power supply problem! You will
probably find some bad caps (capacitors) on the board. They will look
bulged on the top an may be a little leaky (brownish stain). In addition check the ribbon that feeds the lcd controller.
SOURCE: Speaker noise
Could be a capacitor on the board or something entirely different, if it starts to smell funny turn it off quick.
SOURCE: NEC NLT-26HD1 The picture flickers on and off
the main control module has a minor problem and needs to be replaced. eventually you will notice other things start to happen like flashing or colors changing.. take it to a good repair shop...
Testimonial: "Thanks You."
SOURCE: I have a NEC NLT HDTV and have lost the remote
Try website 1-800-Remotes Factory original.To buy an exact remote.
SOURCE: Am wanting a User Manual for the NEC TV Model
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
