Before adjusting volume, set the operation mode to fax
mode (page 16).
Ringer volume
While the unit is idle, press {V} or {^}.
L If there are any documents in the document
entrance, you cannot adjust the volume. Confirm that
there are no documents in the entrance.
To turn the ringer OFF
Press {V} repeatedly to display "RINGER OFF= OK?".
i {SET}
L The unit will not ring.
L To turn the ringer back ON, press {^}.
Ringer pattern
L You can select one of 3 ringer patterns (feature #161
on page 50).
Monitor volume
While using the monitor, press {V} or {^}.
and if it work then say a thanks to your Pakistani Brother.
Hope the ringer and the ******** is enabled. If so there is a possibility that the output amp of the ringer is faulty which can also be linked to the ********. You can reset the phone after removing the battery and setting it to default settings. If this wont work then it need a careful investigation in the output of the ringer.( test ringer if working)
hello,you have to go to your phone settings,then you go to the phone ringer settings,you then set the ringer settings to the step you wish. that will make your phone ringer work as expected and supposed.
hello, i believe have ringer on and ringer off. press the menu, press the profile, then, choose a profile, personalize it. when personalizing you will see ringer on and ringer off change it to ringer on and activate the profile. i am your phone will ring. thanks for using our website
Hit the up or down arrow keys several times. (either key will work) and the ringer will rotate through Ringer off - Ringer low - Ringer high... one set will be a steady ring, the other set will be a warble ring. This works on the phone made for RadioShack with 5.8 GHz on the front and Cat. No. 43-155 under the battery in the battery compartment.
The first thing you have to do is go into the settings and tools menu. Once there got to option 6, call settings then ringer ID make sure it's set to on and then do the same for picture ID. That should take care of the problem. Hope that helps!
