Top one the fan turns on but the heat elements and LED light wont turn on. bottom one works fine. All wires visually look to be in place with adequate power.
SOURCE: Kenmore 47779 double oven; lower oven doesn't work after self clean
Sounds like a thermal overload has opened up during clean. It may be mounted on the back.
SOURCE: Top oven will not heat up
Had a similar problem. The overheat sensor had failed to the open position and the oven control would light up and you could set the temp, but it would drop to 100 degrees and then go blank.
SOURCE: bottom oven of dacor double oven
I found the lower circuit breaker had been tripped. That didn't fix the problem but upon further inspection whoever had worked on the unit years ago had dropped a screwdriver that had lodged between the oven wall and the rear casing and shorted out the lower heating element. I removed the screwdriver and oven works fine now. I don't think that will solve the cmmclow problem but maybee the curcuit breaker is tripped.
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
hope u find this useful. thank you.
SOURCE: Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
