These have a photoelectric eye , much the same as a motion sensor on an outside lamp, just pull this out, clean with a wet wipe, dry with a towel & replace, press the reset switch & your boiler should fire up producing lovely hot water
I would check the metal door on the bottom near the burner, sometimes they come loose and vibrate. If not that then I would suspect the chimney liner inside the tank, I have seen them corrode and start vibrating when the gas is running
Generally, they are a your normal low end hot water heater. I have seen American Standard units last up to 20 years (like mine) with not problems, and I have seen them not last three years before the tank ruptured.
We have more calls on the Rheem and Brandford Whites than American Standards as far an minor problems.
Pros: Cheap; reasonably reliable; parts readily available. Cons: Not energy efficient; tank quality - flexible.
When mine goes would I replace it with another American Standard? No, I would install the Bosch tankless water heater.
i think since "tankless" water htrs entered the market...your plumber referring to a standard w/h means a storage tank wtr htr(stores 40 or more gals) ..most popular brands are a o smith rheem bradford white
Unable to light pilot
Gas supply turned off
Turn on gas supply
Gas **** knob dial not positioned correctly
Check lighting instructions. Set control knob
Defective thermocouple
Check and replace thermocouple
Defective safety magnet assembly
Check and replace gas valve
Pilot burner orifice clogged
Clean or replace
Pilot tube pinched or clogged
Clean, repair or replace
Poor thermocouple connection
Check and tighten
Air in gas line
Purge air from gas line
Thermostat's single use ECO is tripped
Check ECO and replace gas valve
Gas valve defective
Check gas valve
I assume you are talking about an electric water heater. The normal life span of an electric water heater is up to 11 years. Before you replace it, try turning off the unit, turning off the water supply, and draining the tank of any built up rust and sediment. Refill the tank, and turn the power back on and see how it performs. If it is still acting up, look at a replacement. On a positive note, the new water heater should pay for itself in pretty short order due to better insulation saving energy (and replacing with a higher efficiency unit may qualify for a tax credit).
