SOURCE: Need a remote control code for a Sansui TDC2075 TV/VCR/DVD combo
Contact Fox International parts at 1-800-321-6993
or Sansui troubleshooting hotline at 800-289-0980
thanks
SOURCE: sylvania 27 in. tv/vcr/dvd combo remote code
find out who sales sylvania, look at what other tv they sale and try there codes. sears is good for this to.
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
SOURCE: need codes for toshiba tv
You will find the codes you need here : http://www.mykameleon.com/support.html#rs
If the exact code is not listed for your model then you must do the code search. This sometimes takes a while because you have to search through every possible code! Goodluck!!
SOURCE: looking for the code for sylvania tv/vcr combo
with most combo's try the VCR codes and then also program the tv code for the volume controls
if you are missing the programming instructions go to the RS website - support
Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
a DVD Combo device, you will be able to control channel
selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer's Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY
Repeat steps 1 through 5 for each device you want to control.
For future reference,write down each working device
code in the following boxes
OK.
