This condition last for appro. 1-2 minutes, then the piture comes back, a little dark but over time it gets back to regular brightness. Then in about 5 minutes, it does it all over again... This is now a regular, periodic problem.
SOURCE: Sony warms up - picture slowly becomes dark
You are losing screen voltage or whats called the boast voltage most likely. This is probably being caused by a bad capacitor in the sweep power supply. You will need to get a service manual as well as use an ESR type capacitor meter to find the bad capacitor(s). Good Luck
SOURCE: Sony KDS-60A2000 projection TV: power led blinks 4 times
the projector bulb has gone out you need to replace it.
hope this helped
please rate well
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
SOURCE: Screen periodically going black
try dvd if that doesnt go in and out try a new cable box or ddish receiver
SOURCE: I have no picture and light flashes 5 times
If you pull the right side out (as you look at the front), get you ear down to the fan exhaust area and turn the set on. If you do not hear the fan turn or feel air being blown out, then you have a defective fan. It is a common problem.
Hope this helps,
Skyassoc
SOURCE: Problem with Sony KDS-60A2000 60
Hello
The power supply regulator board has the fault. There ie no repair to this board. You have to replace it as card basis.
This is the picture of the said power supply board to your Sony TV.
