AcuRite Acu-Rite 00754 Wireless Thermometer Logo
Paul Anderson Posted on Oct 10, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Time is flashing - AcuRite Acu-Rite 00754 Wireless Thermometer
Marvin
Level 3:
Top Expert:
  • AcuRite Master 85,242 Answers
  • Posted on Oct 10, 2016
Marvin
AcuRite Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29058679
Points
266281
This is caused by a power interruption
Instructions for setting time & date of armitron watch 44/1001?
Set time time / date
Press and hold B (Mode) untill alarm hours flash
Press D (Alarm) to advance these
Press B (Mode) again, seconds will flash,
press D (Alarm) to advance these
Press C (Date), minutes flash, press D to advance these
Press C again, hours flash, press D to advance these
Press C again, month flashes, press D to advance these
Press C again, Date flashes, press D to advance these
Nov 08, 2010 • Watches
10helpful
2answers
Memorex travel speaker with ipod dock speaker system black I cannot set the clock on this item
Hold the "Time Set" button until the time starts flashing, then press the "play/pause" button so that only the hour is flashing. Use the ">>" and "<<" buttons to set the desired hour. Once the hour is set, press the "play/pause" button again so that the minute is flashing. Again, use the ">>" and "<<" buttons to set the desired time.
To change to military time from am/pm, hold the "Time Set" button until the time starts flashing, then press the ">>" button. In order to revert back to am/pm, hold the "Time Set" button until the time starts flashing (if it is not already flashing) and then press the "<<" button.
2answers
4helpful
How do you set the time and alarm on a MI2290 Memorex Ipod Dock system
Here's how to set the time, but I don't know how to set the alarm.
I want to kill KLOMPA
run acroos the walls and reach the top of the walls to gain his height. when you jump (1) hold R1 for few seconds...dagger will automatically flash on the screen...when it flashes, press square button at that time...this will enable 1st attack by which you reach on him...(2) now when he is about to throw you down, again press and hold R1 for few seconds...dagger will automatically flash on the screen...when it flashes, press square button at that time. this will enable 2nd attack. (3) after that again press and hold R1 for few seconds...dagger will automatically flash on the screen...when it flashes, press square button at that time. this will enable 3rd attack and this time his one eye will be gone.
Repeat the above dagger procedure for another wall.
Now when his both eyes are gone, attack him and cut his legs. Now when he is down on his knees, prince will run on his back. Now (1) again press and hold R1 for few seconds...dagger will automatically flash on the screen...when it flashes, press square button at that time. (2) After this prince will jump in the air automatically and dagger will flash at that time automatically. Press square button for another attack at this time.
(3) And at last when prince reach his head again press and hold R1 for few seconds...dagger will automatically flash on the screen...when it flashes, press square button at that time to finish arena boss "Klompa".
In broad sense you have to press R1 and square button, 9 times to kill Klompa....!!!
1helpful
Imagines are dark even in bright light
the flash settings should have been kept in auto mode.if you want the flash always.normally, there is a button near the lcd screen, with the symbol of a lightning flash. when you press it once it sets the flash mode to auto, second time it sets it to "flash always on mode", third time "flash always off" mode.you can refer this process in instruction manual also.thanks for using fixya! please dont forget to rate my solution.
4helpful
The time display won't stop flashing
Q: Why does the time on my clock flash?
A: A flashing display is an indication of low battery power. We recommend using fresh alkaline batteries. We do NOT recommend using rechargeable batteries or heavy duty batteries in any of our digital products. They are not designed for this type of use and may cause the unit to perform as a defective unit or not at all. They will also cause the display to flash 100% of the time.
Check engine light on
Cycle your key, on (not start) off, on, off, on. Leave it on 3rd time, and count check engine flashes. It will be a 2 digit number each time. For example: flash,flash, pause, flash, flash. Is code 22.
Flash,flash,flash,pause,flash,flash,flash, is code 33. There will be a little longer pause after each set of 2 digits. When you get flash,5 times, then flash 5 times again, that's code 55 which means end of trouble code message. have a piece of paper ready, write them down, and get back to us with results.
Flashing time lights...pressed cxl button...not working
Flashed f ...time light flash...pump starts to work...doesn't spin...doesn't cycle...
Flash not working
Hello badgirl721,
Flash needs bit time to get electric charge every time. Cyber-shot has indication of flash charging and will let you know when it will ready/ charged.
Top AcuRite Measuring Tools & Sensors Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you an AcuRite Measuring Tool and Sensor Expert? Answer questions, earn points and help others
