Model is 52440. I tried taking out the fuse, disconnecting the negative wire on the battery, waiting 5 minutes, and trying again. Same problem.
SOURCE: 10kw Generac Guardian not cranking, shows rpm sense loss
Sounds like Generator mode switch should be "ON".
Power off the unit using the toggle
switch on the back. Hold down the 'eject' button and turn the toggle
switch back from off to on. This will run a fan test and should eject
your disc. Remember, this will only work on the 20, 40g models. Not
the backwards compatible units with the 4 usb port holes and the
memory card slots.
You have the infamous YLOD, aka. Yellow
Light of Death. This is the number 1 cause of pS3's dying. It is an
overheating issue linked to your CPU and GPU (the processor chips)
You will need to find a local PS3 repair shop who can repair this. Do
not try to attempt repairs seen on the internet yourself as some
would suggest.You could make things much worse and render the unit
totally unresponsive. The repair process takes about 3 hours.
IT CAN BE FIXED
IS THERE A DISC STUCK INSIDE?
If you have a unit that is not
backwards compatible, any non 60g or 80g then you can retrieve your
disc.
Power off the unit using the toggle switch on the back. Hold down the 'eject' button and turn the toggle switch back from off to on. This will run a fan test and eject your disc. Remember, this will only work on the 20, 40g models. Not the backwards compatible units with the 4 usb port holes and the memory card slots.
not try to attempt repairs seen on the internet yourself. You could
make things much worse and render the unit totally unresponsive. The
IT CAN BE FIXED
FOR THE DISC THAT'S STUCK INSIDE.
disc.
card slots.
