That is not a plug in part that looks like a power board which is not recommended to be used on high power devices like a fireplace . I suggest the fire place should be plugged directly into a power wall outlet .that can handle the current requirements. usually 15 amps max via a fuse or circuit breaker in the switch board of the power feed. .
Did you have other devices plugged into it as well
and before you ask me !
yes I have done this to a power board myself but with an arc welder and other devices plugged into a power board at the same time.
SOURCE: smoke coming in my fireplace
What's probably happening is the low air pressure in your condo, a typical situation with a basement condo, is always drawing air down your chimney, I guess through the badly closing fireplace damper. When there is smoke on the roof from the condo fireplace above, some of that is drawn down your chimney along with the air. The simplest solution is to add enough outside air to your condo so that your chimney is not acting as an air intake.
SOURCE: I have a model GW-2078 electric fireplace that stopped working after a power surge. Any ideas
Likely has a reset button somewhere. Find the manual online
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Yes the same thing happen to me .. I'm looking for replacement cord or to see if anyone knows what happen
