Speaking of syncing iPhone with Outlook, you can take advantage of iTunes to sync contacts.
When the sync is finished, the contacts will show up in the Outlook contacts. Besides syncing contacts, you can also sync iPhone calendars and mails to outlook as well. But if you have noticed, the sync of iTunes is an annoying issue among iPhone users as during the sync of iTunes, the application may erase the available files in their iPhone.
http://www.leawo.org/tutorial/how-to-sync-iphone-with-outlook.html
SOURCE: How to sync contacts from iphone to outlook 2003?
i have outlook 2007 it works fine, or if you have Outlook Business Contact Manager then it will be fine
SOURCE: iPhone sync with Outlook Calendar - Appointment time put on iPhone 1 hr later.
With the Iphone 2.0 or the 3G you can fix the time zones by:
1. Go to Settings
2. Go to Mail, Contacts, Calendars
3. Scroll down to Claendar- Time Zone Support
4. Change the time zone
SOURCE: Iphone sync with Outlook 2003
i want my emails from my Outlook 03 to wireless sync with my iphone
SOURCE: Outlook contacts disappear when I sync with my iphone
Make sure that your sync settings are setup for two way sync. You may have them setup to either overwrite the device, or to overwrite Outlook. It may be under the advance settings.
SOURCE: only want to sync selected contacts from outlook
You will have to move those certain categorized contacts to a new contacts folder in OutlookI. So i outlook create another contacts folder go to the folder tab and right click and select new folder - name it what every you like eg." iPhone Contacts" Copy or move all the contacts you have in outlook that you what to sync with your iphone to that new folder.
In itunes make sure your iphone is connected and then select your device on the left hand panel then select the the info tab at the top make sure sync contacts with: Outlook is selected and then choose Selected groups and tick the new folder you just created in outlook.
Just below that also tick Put new contacts created on this iPhone into group: and the select the group that you want to go in - most likely you will want it to go into the same one (folder)
