I installed Windows 10 and I uninstalled programs that I thought I would not need
No PC told make yes,model no.
100,000 models no person on earth can guess which one
ask at HP.com
or learn to post service tag data
seen here
https://www.pcdied.com/TAG-jive/tag.html#hpdt
both laptops and desktops HP there Pavilions,
it as model # and sub codes and product ID
that shows exact model and country too.
go to HP.com
tell them your service tag data
and the system there tells you what you own
I used "TODO PC trans pro" backup.
say w7 to w10
I did the backup to my file server
then
fresh installed the w10,
and the recovered all apps
the recovery did fail on say 10% of apps
but each one is w7 only app so fully expected.
you never told how many appl programs are installed there. 1 ,10 or 100?\
also make sure all paid apps ,you have
all email COA licenses in your email folders by same name if on the PC backup all local email now. (local email client)
really the big deal is losing 50 licenses
PC trans does not allow license thief.
so the apps all must be re Registered.
lets do a list (fresh w10)
backup all COA licenses to all apps now.
delete all apps not wanted now.
update all apps that are old to w10 versions.
most w10 apps run on w7 too but they tell you that, if you look first.
then run PC trans pro, app backup to other media.
install w10 fresh
recover apps.
done,
the PC needs to be 2010 or newer
is it, none told
we can only beg for PC models.
not told how w10 was installed.
fresh load
or upgrade, from w7,8 ,8.1)
and w10 even does (amazing) w10 to w10 upgrades. (pure bliss and magic if needed)
better yet
ask first
ask if my PC can run w10 and not fail
ask and this can be super easy to answer.
learn that marginal old PCs say 2007-9
might install but to our horror
5 chips in the PC are flat dead (or lame)
like
sound
wifi
Ethernet
and many old USB devices like webcams.
and more lots more. to fail
one more, Video chip GPU is in limp mode.
1/2 dead, and no real drive here exists.
best is a PC with H55 up chipset.
and i3 up and gen2 up best of all i3 ,i5 ,i7 up
for a FUTURE
and if w10 does load and fails some chips
we can replace all those device and cure it.
but takes cash.
Fix "Class not registered" C:/Users/jlfig224/AppData/Roaming/58922d0/f412bfd.7aa665a7
that is a bad app.
the post fails to state
w10 installed with no errors?
and runs ok? as an OS, and a working desktop
and the above error only happens if 1 app is launched , non told.?
nor if device manager bleeds red ink.
I use revo uninstaller to force apps to uninstall.
3 ways to do that via REVO and never fails. used 1000 times.in last 7 years.
most app uninstaller.exe are pure junk
leaving junk in files and and mess in the registry, REVO is the cure and king here.
or
search in the registry for
f412bfd.7aa665a7
see if the name of he app shows up.
solving this riddle.
now , MS answers
class-not-registered
https://answers.microsoft.com/en-us/wind...
one error is clicking on say a PNG or other graphic file /photo
and the app assigned to that task is dead.
case in point you have bobs-w7-only-photo- editor installed
and after w7 to w10 upgrade
bobs app is now born dead.
so you click say a PNG and bam,
so giving this fact what did you do just before
SOURCE: Error
This is a Registry Problem and can be fixed by runing error repair pro or any good error repair software. it will scan and fix the registry.
SOURCE: Error Messages!
that doesn't sound good, dell pc's normally have a recovery partition, so if you don't have any valuable photo's/documents on there you should be-able to restore it to how it came out of the box. On my dell it's restart the PC and while it's booting hold CTRL and F11
That will wipe EVERYTHING on it and restore it to factory settings. so only do it as a last resort, it will only work if dell has put a recovery partition on you machine
SOURCE: error in c :\user\many\appdata\roaming\rasctrnm4.dll missin entry
Insert operating system disk in drive.
Click Start. Click Run. Type
cmd
Hit Enter.
type in command prompt
sfc /scannow
Hit Enter
System file checker will replace the missing files.
after this run reginout intel partner to fix the registry and then open c
SOURCE: ho to fix problem name blue screen
can you post the actual blue screen code?
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
SOURCE: fix Class not registered C:/Users/jlfig224/AppData/Roaming/58922d0/f412bfd.7aa665a7
Looks like you have Malware /
REBOOT / tapping the F8 key on the keyboard... / Select Boot into "SAFE MODE"
Then browse to C:/Users/jlfig224/AppData/Roaming/
DELETE folder : 58922d0/ (and everything in it)
REBOOT ..and reply back with results.
Thanks
Doug
