Im using dvi to hdmi cable. Hp L1925 19 inch display monitor
SOURCE: can i use the dv port on my monitor to display a
Ports on the monitor are for receiving the signals from the sources, not for sending signals out to another devices. Basic LCD monitor and TV troubleshooting guide:
Your TV HDMI should be connected directly to the video source output, not through the monitor.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
SOURCE: laptop hdmi to dvi monitor
Yes that will work fine
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Testimonial: "thank you I'll order the cable."
SOURCE: NO DVI INPUT SIGNAL AND MONITOR GOES TO SLEEP
you can't run 2 different inputs at the same time. VGA takes prescedence.
