Quiero saber si el receptor elite PRO RO6U es compatible con tv plasma pionner PDP 4350HDG
SOURCE: plasma TV mod PDP-5016HD not turning on
The most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
SOURCE: Is my Pioneer 50" plasma PDP-503HDE HD ready?
Yes it is but upto 720P only. It is not full HD(1080P).
SOURCE: Do you have some instructions or a manual for the
Click here to download teh instruction manual
SOURCE: PDP 504 PG. TV Deed
If the power supply has failed then you must check the SMPS unit. The diodes from the secondary sides must be checked including the zener diodes. please check the link below for tips on SMPS service. http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Testimonial: "Flat Panel Televisions >Troubleshooting Flat Panel Televisions PDP 504 PG. TV Deed Problem with the Pioneer Flat Panel Televisions PDP 504 PG. TV Deed . smps out put Voltage 3.3V & 7.6 V . Pl z Guide Me. Pioneer Plasma Tv PDP 504 PG Thanks , Amen INDIA [email protected] "
