SOURCE: neff integrated dishwasher
there are some screws inside the door, around the edge. These would be the first to undo then I think the door would have o be pulled up slightly to relaease.
SOURCE: Dishwasher is not working. When swuitched on it
there is a leak under neath take kick plate and look for float switch
SOURCE: stupid neff semi integrated dishwasher
Hello,W/D here.
Almost everything that is attached to the doors is fitted from inside the door panel. You'll need to remove the inner door to get at the parts. The screws are around the inner edges and the top; not all are of the same length. Make notes if necessary when removing so they go back in the same place upon reassembly. One easy way is to mark the outline of the ends of any screws that are different on a piece of paper, showing where they came from (eg, 2 lines on a piece of paper, 2 inches apart, which is the ends of the screw, showing that they came from either side of the lock, etc.)
Best regards, --W/D--
SOURCE: The door of my Miele G646 SCI semi-integrated
I am not exactly sure if I know how to fix your problem with the door but I found a great site if you want to change the look of your appliances. They even have stainless steel.
www.applianceart.com
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
