Hitachi RB24EAP 23.9cc 2 Stroke 170 MPH Gas Powered Handheld Blower Logo
Bob Chapman Posted on Oct 06, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Hitachi leaf blower was smoking after short term use
My leaf blower almost smelled like was something burning
  • lbrac Mar 21, 2017
    If it was smoking from the muffler/exhaust, it is likely a combination of oils used to produce the blower components burning off and the oil in the fuel mixture. If this describes what you see, it should gradually lessen as the engine heats up and "cooks off" the oils in the muffler. Also, the oil:gas ratio of the fuel mix will tend to smoke more with richer oil:gas ratios (more oil in the gas), and more so when the engine and muffler have not reached full operating temperature.
Marvin
Level 3:
Top Expert:
  • Hitachi Master 85,242 Answers
  • Posted on Oct 06, 2016
Marvin
Hitachi Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29024674
Points
266281
The engine gets hot, and the smell is likely not anything to worry about.
Electrical burning smell
I had one like this. The problem is probably something wrapped around the blower. You may have injested anything from string to a piece of plastic.
2answers
Why is there smoke?
Kindly switch off the TV, switch off power, and remove plug. The TV needs servicing by a qualified service technician.
Heater of car smells
A mouse or leaves from a nearby tree have gotten into the AC/Heater blower motor and they are touching the blower motor speed control resistor, this is very hot and makes them smolder and smoke and smell. You will need to remove the blower motor from the housing that it is in and clean out what ever is in there.
1helpful
I have the Superblower 51591 and the blower turns on, but the engine starts smoking and has a burnt smell so I have to shut it off. Any idea what could be wrong?
There is either something overheating inside the blower, likethe brushes or loose wiring or loss of insulation on the wiring.
Smoking can only mean one thing, and that is...unless you are a licensed electrician or know somebody who is, the best thing is to scrap it and get a new one.
Leaf blower will start, run for about 3 secs, then dies. Blue smoke comes out of it.????
blue smoke is the sign of burnin oil try putting oil in thr cylinder about two tablespoons of oil the blower should run long enough to the oil is burned out that will tell it is the rings but sometimes it will free the rings and keep on running if your lucky
1helpful
My toro blower stopped working after only 10 minutes
Hi, normally when an electric motor smells of burning the damage is done, if it's new you need to get it fixed under warranty, trying to repair it yourself will void warranty
10helpful
Motor smokes
If an electric motor is smoking, most likely it is in the process of burning out the windings in the motor. This usually starts from using an extension cord that has too small a wire or a cord that is too long. when you do thid you are forcing the motor to pull more amps than it should to make up for the voltage loss in the cord.
The fuel for the electric motor is a term called watts. Watts equals volts times amps. If the voltage drops then more amps are needed to feed the motor enough watts. This caused the motor to over heat and this melts or breaks down the insulation on the windings. When this happens the motor starts to short out and once this happens then you can not save the motor.
Electric lawn equipment should be used with #14 or #12 (never use #16 or #18 gauge ) guage extension cords and should not be used with cords longer than 50 feet. Also you should not run the equipment more than 10 minutes with out a 30 minute rest.
2helpful
2answers
My black and decker leafhog blower/vac smells like something is burning
Black and Decker has issued a recall notice for Type 1 BV4000 because "a loose connection between the unit and an extension cord can create heat, posing a possible fire hazard" Says to STOP USING and call 1-866-853-2138 to arrange for free repair. (Found info by Googling "Black and Decker Leafhog", navigate to Black and Decker website and click "Important Safety Recalls" button at bottom of page.)
Top Hitachi Garden Experts
Jay Finke
Jay Finke
john h
Are you a Hitachi Garden Expert? Answer questions, earn points and help others
