Instructions1.
Remove thedoor panel. Refer to your
Honda Accord repair manual for theinstructions in removing the door panel. Unhook the rods and connectors on theinside of the door panel and set it on the floor.
Remove thefilm covering the access to the side
mirror. It's difficult to avoid damaging thefilm while removing it so you will need to purchase a new piece of filmcovering when you buy a new side view mirror.
Reachthrough the service hole into the mirror housing with a screwdriver. Loosen thescrew that holds the mirror. Twist the screw out with your hand.
Reacharound the door and support the mirror with your other hand. Continue to twistthe screw out, then catch the mirror as it drops out when you remove the screwcompletely. Put the screw in a safe place so you don't lose it.
Installthe new side view mirror by positioning it where the old mirror was. Insert thescrew you took out in Step 4 and twist it in with your hand. Insert ascrewdriver into the service hole to tighten the screw.
Replacethe film covering that was damaged when you took out the old mirror. Push itinto place in the indentation on the door.
Sit in thecar seat and adjust the mirror so you can use it properly.
