Is bose acoustimass 10 series iv need an aplifier to work?
SOURCE: How to get good output and effect out of Bose
see the user manual and set the speakers at proper spacing and direction
SOURCE: Bose audio input receiver cable 15 pin
You can buy it on ebay but it's cheaper just to make one. If you can solder, all you need is a female 15-pin d-type connector and a bunch of speaker wire. Here is a diagram of the connections.
SOURCE: Is the subwoofer from the Bose acoustimass 10
The entire speaker system is passive. That is, it requires amplification for each channel.
From the manual: "Compatible with A/V receivers rated from 10 to 200 watts per front channel and 10 to 100 watts per rear channel; rated from 4 to 8 ohms".
