SOURCE: Sir i have a thomson tv model of V21TF02. 15 days
Hello
There is an authorised sevice center for Thomsun in karnataka. You just sech for it on google by entering 'Thomsun auththorised service center in karnataka' in the box. You will get a map showing the location of that service center, which I gets here in Trivandrum, Kerala.
There is no need to insist on to an authorised service center, to get your TV repaired. Just consult with local electronic mechanic, in this case, They can do the needy very easly.
Ok.
SOURCE: THOMSON V21TF02 TV REMOTE
These are the setup codes for Thomson: 0031 0004 0048 0054 0094 0100 0102 0107 0129 0191 0005 0009 0000 0162 0163 0342 0003 0015 0022 0096 0113 0125 0179 0187 0188
SOURCE: remoto for thomson tv model V21TF02
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability.
Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Type in the "brand name only" of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
