Changed fuel filter on a massey furgeson 230 did not prefill it. now it will not start. have fuel coming out of injector pump bleed screws
OOhh well I guess you've learned that its allways a good idea to prefill your fuel filter when replacing it , see my tip for priming diesel trucks (works for tractors too) , well sounds as if now you got air bound injectors (air compresses -fuel doesnot ) you will need to loosten (not remove!!!) injector lines at head till they bubble as you crank engine over , sometimes a quick method ive used is to " spray" paint thinner (mineral sprits) into air intake as I crank , engine should sputter and eventually start as injectors take over fuel delivery
below are just a few of the tractor forum sites i use. these guys are really helpful and someone will have the answer for you. all i can say is to make sure all your levers are in the right position and check the quadrant lever position on your right.
http://forums.yesterdaystractors.com/viewforum.php?f=19&sid=419bda8adfabe7c0757a89cd5e57d483
http://www.ssbtractor.com/wwwboard/Massey_Ferguson_tractors.html
