GE Profile Spectra JGBP90 Gas Kitchen Range Logo
I was given a GE Profile Oven/Stove, the only problem is that a mouse chewed through almost all og the wires inside. Where can I find out theschematics for the wiring so that I can finish?
Mainly need the wiring for the ignion wiring. Hopefully I already haVE THE REST., The model # is JGB908SEK5SS and the serial # is GI280326P.
5 Related Answers
Anonymous
  • 2712 Answers
  • Posted on Oct 04, 2008
SOURCE: Our GE Profile Oven is not heating up (stove works)
Please check here for possible troubleshooting steps:
http://www.repairclinic.com/0088_13_1.asp#Level1_2
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Anonymous
  • Posted on Dec 11, 2008
SOURCE: Ge Profile XL44 - Everything works except the Oven, it just stopped
I figured out what the Issue is with my oven. I took off the back panel, a wire which runs from the teperature control knob to what I think mught be the thermostat is burnt off. I cleaned the wire and temporarily twisted it back on and the oven works now. I will call a tech tomorrow to replace the wire and put the tester on it to make sure the thermostat works properly so the wire wont burn off again or catch the oven on fire.
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Jan 11, 2009
SOURCE: GE XL44 propane to natural gas conversion.
your going back to natural from LP??? of so tyhere is no new orifice , but hte "hood" on the end of the bake, needs to be adjusted out"loosened", LP the "hood" is secured snugged down,
Anonymous
  • 3361 Answers
  • Posted on Feb 21, 2009
SOURCE: GE Profile Oven does not work although stove does
Check and or replace the glow bar ignitor.
Anonymous
  • 1136 Answers
  • Posted on May 27, 2009
Hi, You will need to use a 1/2" wrench and turn the orfice for the oven 2 turns counter clockwise.
Make sure you flip the plunger over on the regulator also.
After doing these things, watch the flame in the oven to make sure no other adjustment is needed.
Please let me know if this helps or if I can assist you further.
Vic
1helpful
The control panel went out the oven fan still blows but the oven does not heat up nor do the panel light up
if this is a new oven/stove its possible there is a fuse that has went out. pull away from wall (unplug) start looking everywhere you can for a fuse, keep a magnet handy to keep your screws together, or just place in a bowl. also a flashlight is handy. try to hunt down the issue yourself if you cant afford to have it serviced. I had my refrigerator stop cooling , fan was blowing just no cold air, I pulled it out and looked inside the motor area and noticed a wire had been chewed in half by a mouse, unplugged it ,spliced the wires back together, black tape, plugged back in and shazam ! fixed..then the mouse hunt began!! good luck
GE XL44 Gas Stove & Oven: When using self cleaning oven can I put the stove cooking racks inside to clean also?,
Is this my wife asking this ? lol, i had the same arguement with her, dont leave the racks in, it will tarnish them possibly bend them,that stove gets up to 900 F
1helpful
2answers
GE Profile Spectra Electric Oven.
call a appliance and parts store give them the tear and model number from stove it is inside the door or on back it5 mkay also be on the top under the fuse panel access door
GE Profile stove not working
If neither bake or broil ignitors work you must first verify voltage to the parts.
Most likely a defective electronic control.
Oven will not light
check the gas valve to make sure a mouse did not chew the wires.
Ge oven codes
F2 means your oven temp got too high. At least, that's what the control boards thinks. More than likely you have a bad oven sensor or bad wire to it or a bad connection somewhere between the board and sensor.
2answers
GE Profile Performance Double Oven
I was getting only the F0 error code. The wiring diagram inside the stove said F0 indicated a bad off button on the keypanel. There were instructions to check the ribbon cable on certain lines, with values for the resistance. It seemed to check out, so I ordered a replacement and voila, it worked.
9helpful
2answers
GE Profile Spectra XL44 oven wouldn't light, stove top and broiler works
We have our second GE stove and it has started to do the same as the rest of you.  Our first stove began to suffer igniter issues after 4 or 5 years.  I called GE and was given a simple test procedure for the igniter using a multimeter that I don't remember and likely wouldn't post regardless lest someone do things incorrectly... In any event, as I understand, the gas flow is tied to the igniter temp.  As the igniter ages, the temp that it can achieve gets lower. Eventually, it hits a point where the temperature isn't sufficient to reliably ignite the gas and our problems start.  The solution is fairly simple.  Replace the igniter. So, call a repair person and tell them the problem.  They can come out and instal the new igniter.  Unless you are a licensed or certified repair person, DO NOT DO THIS YOURSELF.  Let the pros handle repair to gas appliances.
The touch pad panel on stove is blank
on the ge range, you need an ERC its the main control for the oven. yes its costly. comes in a kit with a new wire harness
Top Kitchen Ranges Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a Kitchen Range Expert? Answer questions, earn points and help others
