Home Security Logo
A
Anonymous Posted on Oct 04, 2016
I've just replaced the batteries in my door bell receiver but it still won't work can u help plz
Larry
Level 2:
Habit-Forming:
  • Expert 126 Answers
  • Posted on Oct 04, 2016
 Larry
Expert
Level 2:
Habit-Forming:
Answers
126
Questions
0
Helped
63926
Points
344
Did you replace them in the door switch?
Make sure you have them installed in the correct polarity.
also make sure any dip switches that sync the devices were not moved out of position inadvertently.
Make sure the channel number is also sync if you don't make internal switch changes
1helpful
I have a blyss door bell with additional plug-in bell. The bell works fine but an orange light flashes on the plug-in bell.
Try this:
Reset the Unit
- remove all the batteries from the bell
- ensure the battery in the doorbell unit is working and remove the back cover
- replace the batteries in the bell unit
- within 30 seconds of the bell unit sounding the bell, press the melody changer button on the back of the door bell unit once
Pair the Unit
- wait at least a minute after reset
- within 30 seconds of the bell unit sounding the bell, press the door bell button
1helpful
2answers
Why has my Honeywell DC313NHGBS plug-in wireless door bell unit suddenly stopped working. The battery unit is fine.
Door ringer is defective or the doorbell transmitter is not sending a signal or the bell is not receiving the signal due to a part failure.
1helpful
2answers
Blyss Wireless Doorbell need to re sync it but lost the instructions ...theres a Button on back of the sounder ..have tried various combos but nothing working !
There are only picture instructions but from what it implies...
Reset the Unit
Pair the Unit
their helpline is: 0845 2301231
I have a Paget Trading wireless door bell. How do you get into the door bell button. Is there a battrey in it?
Yes, there is a small battery in the door bell button, use a small screwdriver to carefully pry it apart, make sure the transmitter and receiver are on the same frequency and within range of each other.... really hope this helps?
My LG cell phone doesn't turn on for me. I've tried lots to get it to work but it won't work! Plz help!!!!!!!!!
Hi,this problem is not a single question and doesnt have a single answer,all inside circuit include battery must be checked, may be the battery is gone may be mother board problem or break up maybe dust or humid problem and or even software problem,go to certified repair store to fix it for you
kind regards
Apr 17, 2013 • Cell Phones
1helpful
3answers
Phantom bell rings on Siemens wirreless door bell chime jsjs-204, I do not have instructions
You may need to change the frequency of the chime. In this model, you need to remove the batteries from the receiver unit and wait for a while. Then replace the batteries. The doorbell unit should automatically set itself to a different frequency once you press the button, which will(hopefully) solve the problem.
It seems impossible to find the instruction manual for the doorbell. But see http://oddsnsods.net/blog/?p=68 who had a similar problem with a different Siemens model, which works on the same principles. (I can't seem to be able to remove the battery from the door bell unit on the jsjs204, but it reset itself after changing the batteries in the receiver).
31helpful
How to program 9242 remote to work with my Bell
The following instructions will enable the Bell 9242 remote to operate a Bell 5900 receiver. Remove back battery cover. Just below the "Bell" lettering on the front of the remote, there is a half moon shaped plastic insert "key" that slids out downward. Turn over the plastic key and reinsert back into postion and replace the battery cover. Success!
Top The Home Security Experts
vince
Paul Carew
Are you a The Home Security Expert? Answer questions, earn points and help others
