I know the size of the light bulb, but I need to know how to change it.
You might check out some of the older Bernina manuals to get an idea of how it may work in your machine. The 1260 is the closest manual available. Looks like your machine takes the same push-in bulb. So, you would push up on the bulb and twist. Then you would install the replacement the same way. Sometimes, using tight fitting medical gloves helps grip the bulb in order to twist.
BERNINA Sewing Systems
BTW--I have older Berninas and upgraded their bulbs to LED.
