I was replacing the print cartridge and it apparently did not fit properly. I discovered this after I closed the print cartridge door. Now the print cartridge door will not open and I cannot properly align the print cartridge door. What can I do? Thanks.
SOURCE: HP Laser Jet 3055- "No print cartridge" message
This could also happen due to the censors.
Try these steps.
1. Take all the papers out from input tray.
2. Open the cart door & take the cart out,and let the door be open.
3. Turn Off the printer.
4. Clean the metal contacts on the cart.
5. Reinsert the papers & the cart.
6. Turn the printer on.
This could resolve the issue.
All the Best!!!!!!
SOURCE: Error message: "Door Open"
HI there,
Follow the steps below:
Step one: Close the print cartridge access door
1.Verify that the print cartridge access door is completely closed. It may appear to be closed, but if it is not completely closed, the error message will display. Verify that there are no obstructions blocking the door.
2.If you are unsure how to close the print cartridge access door on your model, consult your User Guide for more information.
Figure 1: Examples of closing the print cartridge access door (your model may vary)
If you have attempted to completely close the access door and the error still appears, there may be a problem with the door sensor and the unit may require service.
Step two: Service your product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Good Luck!!!
neo
SOURCE: HP OfficeJet 6110 All-In-One
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
812
SOURCE: cartridge jams
remove the cartridge and directly off the printer let the carriage remain in center.then with your hand manually move the carriage from left to right.3 to 4 times.then on the printer and insert the cartridge after cleaning it with dry tissue.then check out.also in the back side of the printer there is access door to remove the paper if jammed so check out there also if any paper jammed.
thanks.
