Here is the manual for that printer, please look at Troubleshooting to figure out what's wrong.
Sharp AR 203E All in one printer scanner copier User Guide Manual
SOURCE: I Want Printer driver for AR-5316
http://www.sharp.co.za/techweb/drivers/copierdrivers/gdidrivers/gdidrivers_5316-5320.htm
welcome to pattaya thailand
SOURCE: cant enter simulation in sharp ar m207
Try # * Clear *, it will ask you to enter simulation code. Type 14 then press start. Then press 1 for yes and start again. The machine should then restart and the error code should be cleared.
SOURCE: DELETED IMAGE IN REDUCTION MODE REDUCTION A3- A4 ONLY
you must select paper size also original size on your copier,and check indicators.
SOURCE: AR-M150 shows h4 but it does'nt have interrupt key
There is need to solve the low current problem by simply rectifying it frfom the power supply.
enter simulation (use SIM14) 'C' 'auto' 'C' 14 copy key
