Hello I had my dash exposed to a little water when I was changing the battery.. although I wiped away any moisture it initially worked then 1 day later I could not not get it to get out of the green screen.. Is there any way of recovering what is on the phone?please help Greg
Do a sw reset. turn the phone off, press and hold the soft keys (buttons with the lines on them above the home key and back arrow key) and hold it down.....press the power button while you are doing that until the white t-mobile screen will come on, then instead of going to the green windows mobile screen, a black screen with white writing......press the green button....it will get you in your phone but it will erase your info as a result....
What if the hard reset does not work and you end up with the green screen, then it goes to the white t-mobile screen again and freezes? In addition to that I cannot get it to show a connection with Windows Mobile Device Center on Vista. So there is no way to do a software upgrade. Is there a solution if you cannot reset?
I also experienced the same problem, but my outcome is a little different. My dash is working as normal, but now my the - key and the green phone key (to call out and accept incoming calls) any working anymore. Is there anyway to fix it?? Please help!!!
I tryed that and i got the black screen with writing on it. pressed send and then it went to the green screen again. Ive tried doing the same thing and it just goes to the green screen any more ideas?
same here, i try the soft keys and still dont wanna work, any ideas?
I did follow the instruction that you stated but the screen went black any help with that?
I have had this phone 3 weeks. (brand new) I rebooted phone and now is stuck on the windows mobile screen.
i dont want to lose my stuff on the phone though...
my stupid phone is stuck on the grren screen as well...
