Kenmore 62622 Microwave Oven Logo
Posted on Nov 19, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ticking sound when running microwave
When i run the microwave i hear a ticking sound. it has no problem heating the cup of water
  • MikeD2 Jun 22, 2008
    I have the same problem with my Kenmore over the range Model #636893.
    Microwave works fine but in the last few days it started making a "ticking" or slight "buzzing" sound while running. It is about 4 years old.
    Any suggestions would be appreciated. Thanks.
William Miller
Level 3:
  • Kenmore Master 9,179 Answers
  • Posted on Nov 22, 2007
William Miller
Kenmore Master
Level 3:
Answers
9179
Questions
Helped
4478233
Points
21747
It may be a noise coming from the turntable motor or stirrer motor, if so equipped.
If it's not too loud, I wouldn't worry about it unless it gets louder or you get further symptoms.
Hi, I have an over the range microwave oven that just stopped working. When you close the door it just keeps running and won't shut off. I unplugged it and plugged it back in and checked the breaker.
SOMETIMES A DOOR SWITCH GOES BAD AND BACK FEEDS POWER THAT RUNS THE FAN AND IF IT HAS IT SOMETIMES THE TURNTABLE TOO SO YOU HEAR THE FAN RUN ALL THE TIME BUT TYPICALLY IT IS NOT HEATING. YOU COULD PUT A SMALL CUP OF WATER INSIDE TO SEE IF IT IS HEATING, PROBABLY BAD DOOR SWITCHES OR BAD CONTROLLER.
Clicking sound ge microwave spacemaker xl1400
There should be a buzzer sound that is made by a piezo. If it isn't sounding correctly then it must have a bad solder joint on it, or the ic that controls it is malfunctioning
My GE jvm2070BH002 Microwave starts but stops.
Sounds like the control board. Not many parts in a microwave oven. That is the only one that generally goes intermt
The microwave has power and seems to respond to keypad, but does not heat. I tried many auto and manuel settings. It also makes sort of ticking or scratching sound when turned on.
HI:
The most common reason for no heating is the High voltage diode fails causing the no heating problem, if you are hearing so sort to ticking sound the diode may of come loose from the high voltage capacitor inside the unit and is sparking. I would have the unit checked for loose connections inside the unit, I don't unless you have experience working on microwaves, recommened you try repairing it yourself, as there is alot of voltage on the capacitor circuit of microwaves, at least 10,000 volts at its terminals, and need to be discharged before any service is atempted.
1helpful
Microwave quite heating. Tried cup of water, but not heating. The fan is running but sounds abnormal. The lights are on and the turntable moves.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Whirlpool MH3184XP Microwave Turns On, Heats, but sounds like fans not working. 4 years old, fans worked fine until they seem not as loud anymore. The magnetron is working fine as it heats (did the 1 cup...
Suggest you pull the plug out, remove outer cover and place a cup of water into the micro. Set power to minimum then switch on and take note if the fan works or not. If not, switch off immediately and have it replaced(magnatron will burn out if left to run without fan.)
5helpful
Microwave
Hi
3 things can fail - the control board, the inverter board, or the magnetron. If the microwave runs for about 7 seconds with a ticking sound..then stops and shows "F-9", it is the magnetron that has failed. The fact that the unit starts and runs with the TICKING SOUND means the control board is sending signal to inverter board and the inverter board is sending signal to magnetron. Magnetron is covered by full 5 year warranty, inverter board is only 3 years.
If this is not the case then it could be a defective control board, inverter or line voltage too high.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Model 72180883400
F-9 error code indicates a defective control board, inverter or line voltage too high. f the microwave runs for about 7 seconds with a ticking sound..then stops and shows "F-9", it is the magnetron that has failed. The fact that the unit starts and runs with the TICKING SOUND means the control board is sending signal to inverter board and the inverter board is sending signal to magnetron. Magnetron is covered by full 5 year warranty, inverter board is only 3 years.
F-9 Error after running a few seconds...
If this is a "SmartWave" branded microwave oven then F9 is an error that indicates an inverter board or magnetron has failed. Either way.. Try this...With the F9 error cleared, start the oven and listen for a ticking sound. The inverter will attempt to 'fire' the magnetron 5 times.(ticking sound). If can hear ticking, replace magnetron....Else in may be a door switch problem
3helpful
2answers
Kemore microwave model number 721.63763300
has failed. With the F9 error cleared, start the oven and
ticking, replace magnetron. Check owners manual. Part may be covered by limited warranty.
Top Kenmore Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
