No, that's the model type code (5JWA) and the country (070 for England). The paint code is the single letter next to the black dot below that number.
A for "Deep Purplish Blue Metallic C"
B for "Dull Red Metallic D"
C for "Silver Metallic 1"
Usually means that either the touch pad or the oven control (also called
clock or ERC) is defective and needs to be replaced. If this fault code
cannot be cancelled, replace the oven control (also called clock or ERC),
touch pad, or both.
Only solve with replace control board (also called ERC or clock).
Hope this helps.
Using logarithms. For example, if A ^ X = 2; then X = logA(2);
This calculator only works in base-10 logarithms or natural logarithms, you should use the base conversion formula.
logA(X) = logC(X) / logC(A).
there are 3 screens.
1st one is smooth part number 4-071-582-01 subs to 4-081-065-01
2nd one is called lenticular part number 4-070-281-11 alternate part4-070-525-01
3rd one is called fresnel part number 4-070-602-01 alternate number 4-070-602-11
once you remove the screws from the back top and sides you will have screws in the bottom,you have to remove speaker grill to get to them.lay screen flat on floor then remove screws arround screen to take it out-reverse this process to reinstall parts
HRMC 15 Code Scanning method...
1.Press TV device button on the HMRC 15
2. Press Select and Mute simultaneously until TV device button flashes.
3. TV device Button should now stay lit.
4. Aim Remote at TV
5. Press The CHANNEL button UP ...repeat until your TV turns off.
6. Press Power Button to turn TV back on (Thus confirming you found the right code).
7. Press the TV device button to lock in code.
8. ENJOY !!!
