I have changed my radiator, thermostat, water pump, timing belt, temp sensor and added a new fan. I have not changed the coolant reservoir.
If you are adding coolant every day then you are experiencing coolant loss
could be from a leaking pump gasket , head gasket or other leaking item
have a compression test done to check for head gasket , cracked head
next have the cooling system pressure tested to find the cooling leak
lastly check the fan, fan relay , fuses and coolant temp sensor unit for correct operation
if you are adding coolant every day then you are experiencing coolant loss
