Washing Machines Logo
Mark Chen Posted on Sep 29, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My whirlpool calypso washer wont spin in all washing prosdure, can you tell me whats wrong?
It won't spin in whole washing cycle.
Jerry Kramer
Level 3:
  • Whirlpool Master 3,933 Answers
  • Posted on Sep 29, 2016
Jerry Kramer
Whirlpool Master
Level 3:
Answers
3933
Questions
Helped
880901
Points
12076
There is a belt that drives it. I am sure that is broken or stretched out to a point it cannot spin the tub.
5 Related Answers
Anonymous
  • 83 Answers
  • Posted on Nov 30, 2007
SOURCE: Whirlpool Washer wont spin or drain
check your lid switch. if it will aggitate and not spin or drain.. then your lid switch is your answer
Anonymous
  • 65 Answers
  • Posted on Feb 18, 2008
SOURCE: Whirlpool washer problem
run the waher in a high spin and lift the lid repeat this three or four times and your brakes will free up and begin working again
jonniewalker
Starnley Johnwells
  • 1031 Answers
  • Posted on Sep 21, 2008
SOURCE: Whirlpool top Loading washing machine won't spin on spin cycle
If the washer won't finish a spin cycle, it probably means that your timer went bad or stalled. You can take the control panel off and look at the contacts for scorching or corrosion.
Anonymous
  • 90 Answers
  • Posted on Jan 19, 2009
SOURCE: whirlpool washer wont spin during high spin cycle
Try www.Repairclinic.com.
Anonymous
  • Posted on Jun 02, 2009
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Whirlpool Calypso Washer Mdl#30942 gets stuck during rinse cycle. Machine runs, then stops, but does not rinse completely. Last 35-38 min cycle is problematic. What is wrong and how to fix it?
It's hard to tell by your description of the problem, but it sounds like it could be the timer If it's not running while in spin mode, or as simple as a belt if it's running and not spinning fast enough.
Washer won't do spin cycle....and won't start any cycle
Hello & Welcome to FixYa
When the washer fills but does not agitate or spin then you can check if the lid switch is fine. You can jump start the lid switch by connecting both the wires with each other or use the third wire to act as jumper between the two. After this if the problem is solved then replacing lid switch is recommended repair. Please get back to me if you have any other questions.
Kevin
I am just trying to figure out how many cubic feet my whirlpool calypso washer (model gvw9959kq2) is? Thank you.
The 3.5 cu ft Whirlpool GVW9959K is a unique washing machine that is Energy Star Qualified. It features the Calypso technology which helps prevent piling, shrinking and provides excellent stain removal. Save money and energy (up to $100 in utility bill savings) with this Energy Star Quiet Wash washer. The multiple cycles which include the hand washables cycle, the wool cycle, the bulky items cycle, give you the many options you need in determining the right cycle for your laundry. Automatic water level settings, multiple wash/spin speed combinations, 5 wash/rinse temperature combinations, and stainless steel wash basket with limited lifetime warranty are just some of the many reasons why this washer is the best choice for you. However the washer has a quirkiness also. They tend eat garments from time to time and take a dump when overdosed on detergent. The basket is suspended on four rods and is easily removed for servicing the motor and pump. The pump has a motor mounted on it. The whole time the washer is in motion water is continually poured over the clothes. It has a heck of a spin cycle at the end. Theory of operation, how to operate, repair and diagnose them fault does is HERE in the service manual.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1helpful
Our Kenmore Calypso 110.21082 is making a thumping sound in the wash cycle but not during the spin cycle. Seems to thump a little louder with every load. Any suggestions?
This washer has a very complex ujoint system that make the wash plate "nutate" as Whirlpool defines it. Something may be wrong with this system. I recommend having a pro do this job unless you have good mechanical prowess.
Whirlpool calypso model GVW9959K-0 leaking during rinse cycle
hi my name is joyce
Sounds like your pump is leaking. if it is leaking when you are on a spin cycle.
now if it is stuck on f1 cycle and wont drain unplug and let stay unpluged for 60 seconds and replug and see if you can restart on drain and spin cycle. let me know if I can help with any other problems.
thanks
joyce
2helpful
Wash machine won't start in spin cycle
Lid Switch needs to be replace. Washer wont spin without lid switch.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Washer Wont spin
The whirlpool calypso was a lemon!!! if i were you i would buy another machine. They have many problems! Pumps go out very frequently and they are over 80 dollars. Save and buy a new machine... Sorry for the bad news.
Calypso won't finish spin cycle
Error is Insufficient cycle!
first try to unplug the appliance for 5 minutes and then restart it and see if the system reset!
if not you need hands on service. Not every situation is easy.
Please let me know what happened?
Plese rate me at our site too, before you sign off!
Thank You for using our service!
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
