Question about Refrigerators
How to fix error code H1
I set the fridge to 6 but error codes keep coming back
    Sergeant:
  • 182 Answers
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Posted on Sep 28, 2016
Anonymous
SOURCE:
My side by side frigidaire was giving me a H1 code so i unplugged it for 3 days and as soon as i plugged it back in it gave me the H1 code. How do i fix this problem?
HI error means unit has detected temps are too high in either fridge or freezer. Since you’ve already unplugged it and code came back, you’ll have to determine what’s causing the temperature problems
Oct 05, 2018 | Frigidaire Refrigerators
Have error code H1 on my freezer. I have it set on 5 what does it need to be
Jul 05, 2017 | Refrigerators
The display stopped showing temps and displayed a "6". The actual temperatures dropped to freezing. I unplugged the unit a few times for up to 2 days but the same issue developed.
Whirlpool Refrigerator Error Code: Flashing 6 on the fridge display
Condition: The 6th Sense technology is activated - If you put warm food in the refrigerator or leave the door open, the 6th Sense technology kicks on to return the refrigerator to the set temperature. The flashing 6 should go away once it gets back to the right temperature.
Part or Parts: Allow fridge to get back to temp on its own (no parts required)
Whirlpool Refrigerator Error Code: 6 on the fridge display
Condition: Computer error
Check: Remove power for 5 minutes
Part or Parts: If code returns replace mother board
Apr 29, 2016 | Avanti Refrigerators
Side by side fridgidare wont stop beeping and showing H1, freezer door was cracked all night and our ac was out, tried to unplug and reset still nothing???
Hey Nikkie, I appreciate your post!
I see that your Frigidaire refrigerator is beeping and displaying the error code of "H1". An "H1" error code means that this is a high temperature within the refrigerator. Since the door was left open all night the refrigerator is registering there is a high temperature. I would suggest keeping the door closed and allowing the refrigerator to get back to the correct temperature. This may take anywhere from 24 to 36 hours for the temperature to stabilize. Hopefully this information is helpful to you. -Matt
Dec 25, 2015 | Frigidaire 26.0 Cu. Ft. Side-by-Side...
H 1 flashing Frigidaire side by side
I appreciate your post, Sharon!
From the information you have provided your Frigidaire side by side refrigerator is displaying an "H1" error code. I was unable to locate that error code but I did find the error code "HI" which stands for high temperature inside of your freezer compartment. Check your freezer is it still cooling? If so it may just be a miscommunication within your refrigerator and you can clear that by disconnecting the power cord for roughly ten minutes. If you continue to experience an issue I would recommend having a professional technician out to perform a proper diagnosis and repair. This will help you avoid any unnecessary part purchases. Best of luck! -Matt
Mar 24, 2015 | Frigidaire Refrigerators
Hotpoint fridge freezer ff200 tx displays error code A1?
These tempratures are pretty cold should be around 0 deg. but it sounds like you might have a bad defrost timer or defrost thermostat the frost should not come back if defrost system is working
Jul 26, 2014 | Hotpoint Freezers
Fridgeaire error code H1
Hello - Could it possibly be HI? Typically error code HI indicates that the unit has detected high temperature in freezer. Try setting the unit to a lower setting. Generally the factory setting is 0 for the freezer temperature and 37 for the fresh food temperature.
Oct 13, 2012 | Frigidaire FSC23F7DSB Stainless Steel Side...
Samsung washing machine error h1
hi !
look here : http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3369-generic-daewoo-washing-machine-and-washer-dryer-fault-codes.html
Aug 13, 2012 | Washing Machines
Sub-Zero PRO48 fridge - Error Code 40 and EC91
Here are the most common Sub-Zero error codes:
Sub-Zero Error Code EC40: Freezer will not stop running
Sub-Zero Error Code EC50: Refrigerator runs too much
Sub-Zero Error Code EC24: Defroster is not heating enough
Sub-Zero Error Code EC 06: Evaporator thermistor reads inconsistent temperatures
Sub-Zero Error Code EC20: Defrost Bi-Metal Operation is faulty
Larry Rogers
http://sparkleappliance.com/ca/sub-zero-refrigerator-repair-los-angeles
Nov 08, 2009 | Sub-Zero PRO 48 Side by Side Refrigerator
Kenmore elite refrigerator error code er if
Bad icemaker fan. When looking in the freezer, its the one on the left.
Sep 01, 2008 | Kenmore 73503 Stainless Steel Bottom...
Refrigerators Logo
2,620 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
