SOURCE: K-beater is stuck on our Kenwood Chef and we can't remove it
I couldn't remove the K-Beater as when I tried to turn it the whole mechanism turned with it. I couldn't even remove the splashguard! I was going to take it to the Kenwood factory (a few miles from home) but then I thought I'd give it one more go and this is what I did...
Perhaps someone can suggest how to stop it happening again. I haven't attached anything since but will update this post if I have any other helpful tips.
SOURCE: can't remove beater kmix from machine. it's stuck!kenwood
Here's how to fix the stuck implement problem:
The implements
each have adjustable heights. to adjust the height you need to loosen
the bolt at the top with a 14mm spanner. If the bolt was loose when it
was being used then it can get too short and not leave enough clearance
between the bolt and the machine in order to push up and turn to release
the implement. If this happens take the open ended spanner, grasp the
implement and rotate the spanner clockwise (when looking up at the
machine from below. Once the nut is loose rotate the implement until
there is enough clearance to remove it normally.
