Garden Logo
John Lehnhart Posted on Sep 25, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fuel system Husqvarna mower
My wife put dirty diesel fuel in the mower and ran it until it quit, which did not take long. I drained the tank, lines, filter and pump. When I took the float bowl off of the carburator to drain and clean it, it was dry. What am I missing here? The machine still won't start. I have good spark and it will fire with a bit of gas in the throat,
Joseph Mueller
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 346 Answers
  • Posted on Oct 01, 2016
Joseph Mueller
Expert
Level 2:
Mentor:
Answers
346
Questions
Helped
171878
Points
784
In the carburetor, the needle and seat above the float are stuck shut most likely. Make sure the float will move up and down. you should get a fuel flow when the float drops below horizontal. If this does not happen you will need to blow through the fuel lines to clean them out.
Best,
Joe Mueller
What should I use to clean the tank and fuel lines of diesel in a gasoline powered zero turn mower?
Most ordinary petrol engines can cope with up to 10% diesel (in warm weather) in the fuel so it isn't really necessary to clean the fuel tank and lines - it is sufficient to drain the diesel from the fuel system and refill with clean fuel of the correct type.
My wife put diesel fuel in the gas tank trying to help me. I have drained all the fuel put new fuel filter on and it still will not start. I think there must be diesel in the carburetor bowl. Is it...
squirt some gas in the carb and start it up it will only run for a few secs so quickly keep squirting gas in ,but not to much as to flood it and that should burn the diesel out and shortly it should keep running
2helpful
I accidently put diesel in my John Deere riding lawn mower. How do I safely drain the tank. Or do I need to take the tank completely off? If so I need directions.
If you did not try to start it, you will need to siphon, pump or **** out the fuel tank. The last J.D. that I emptied the tank in I used a turkey baster to draw out the bad fuel. I guess you use what you got. Hopefully your fuel is pumped to the engine and the fuel line goes into the tank from the top. If so all you have to do is empty and replace with gas. If the fuel line drains the tank from the bottom and/or you tried to start it with diesel in it you will need to (after emptying the tank) remove the fuel line from the carb. and direct it to a container, remove the bowl nut of the carb. to drain carb. be ready to clean up a little spilt fuel catch if you can or have rags under and ready. Turn the ignition key for engine to turn over to operate the fuel pump and clear the line. Put a little gas in tank and flush fuel line by using fuel pump to clear. Change fuel filter and put everything back together. Remove and clean/replace spark plug. Test it. Inspect spark plug again if necessary.
Jul 07, 2011 • Garden
2answers
My fuel tank runs on diesel I put premium unleaded gas in error Need to drain the tank It is a 2005 pathfinder 7 seater Help! [email protected]
JUST DRAIN OUT GASOLINE IN FUEL TANK.CHANGE FUEL FILTER AND.FILL UP TANK WITH DIESEL FUEL. ENGINE WILL RUN ROUGH UNTIL ALL GASOLINE LEAVES THE FUEL LINES.
2answers
I put petrol in a 2.5 liter desil turbo delica mitsi van 95 wat do i do to fix it
drain gas tank, fuel lines. replace fuel filter. refill gas tank with diesel. bleed fuel lines and fill fuel filter with clean diesel.
John deere 2140 had gas put in it instead of diesal what going to happen
Don't run it until you've completely drained and flushed and refilled the fuel system, tank, lines, pump...
Don't run it! Diesel fuel is more of an oil whereas gas is more volitile... Avoid starting or running to prevent any damage to your engine!
3answers
How to drain ford fusion fuel tank
The "MOST EFFECTIVE
" way is to REMOVE The FUEL TANK and DRAIN it By Tipping it over to Pour From FUEL INLET HOSE. Im Sure you Dont want to Here this as it Requires Much WORK . , BUT It IS The MOST EFFECTIVE Way to EMPTY The TANK.
1helpful
2answers
Ford fusion 1.4 tdci will not start unless the hand pump is used
HAVE YOU CHECKED THE FUEL LINES WHERE THE FUEL PRIMING PUMP IS CONNECTED FOR ANY CHAFFING THEY ARE COMMON FOR CHAFFING BESIDE THE FUEL FILTER WHICH WOULD EXPLAIN WHY FUEL IS RETURNING TO FUEL TANK.
Gas in Diesel Tank
not good.....need to drain tank first and refill with correct fuel...then you will need to drain and flush the fuel lines and injector pump....bleed the pump and lines and injectors and cross your fingers....good luck
Diesel in gas in a 2008 Yaris
I would recommend draining the tank, replacing the fuel filter, you will probably have to replace the spark pugs as well. You may want to also blow out the fuel lines if easily accessible. Put in new gasoline, a fuel system additive, and run it for a little bit (may get some smoke for a bit, and my be hard to start at first and run rough). Hope this helps.
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
