Model SHY66C05UC/14
SOURCE: Whirlpool ADP951 Dishwasher
Processor board sound bad. May be a loose plug ( or corroded connection on the plug ) . Unplug the dish washer from the wall plug before servicing. The open the front panel to expose the panel control board. Unplug the panel plugs and inspect them to assure no corrotion is apparent. If you see corrotion, use a pencil erracer to clean all contact points on the board and clean the plug the best possible. Plug the dishwasher plug back in the wall and check the unit for proper operation. If the operation is not correct, replace the circuit board. I hope this helps
Ed
NC Electronic
Mills, Wyoming
SOURCE: My Bosch dishwasher model #SHU43C05UC/14
open machine when running and check both spray arms rotating - you will get a bit of water out. if spray arms not rotating, usual cause is debris in the arms. the spray arms only rotate by water jetting from angled jets at the end of the arms. take them out and make sure all debris removed
SOURCE: Whirlpool ADP 905 wash cycle not progressing
There are a couple failures (major) that can cause these problems. A failed pump//motor is at teh top of the list.
It is past the point of simple, home repair and it is time to consider either a service call or replacement.
SOURCE: kenmore dishwasher has stopped draining.
remove the kick panel below the door, place a pan, etc under where the drain hose connects to the drain extension tube, and slide the clamp back some so you can slide the hose off of the extension tube (white plastic tube) and drain any excess fluid into the aforementioned pan, etc., then unscrew the extension tube and check for plugs, or restrictions.
the sump may also be pluged beneath the strainer assembly, and that requires removing the lower spray arm, the water tube that runs up the inside back of the unit, and the upper parts of the assembly below them to access the drain/pump sump area.
last but not least the impeller is jamed and might be able to be freed by removing whatever has lodged within there..
ya never know...
best of luck,
ttfn
SOURCE: Hobart AM-14 water temperature not maintained
Hobart AM-14 will wash and rinse in manual, but not in automatic
My EWD1477 was doing this a year ago and I fixed it. Then it started
doing it again a month ago and I seem to have cleared it again.
Firstly, remove the drain hose from where it is inserted into a laundry
sink hole to make sure it is not blocked or sealed in with sludge.
Secondly, make sure the machine is empty of water and clothes and then turn
the machine to off with the Program Selector Dial. Then turn off the power at
the socket and remove the power plug and leave for five minutes.
Step 1: put the plug back in and turn the power back on.
Step 2: turn the selector switch to the right (Whites/Intensive). The green light of the Start/Pause button
should be flashing and the green lights on for Prewash/wash, Rinses and
Spinning. Don't press any other buttons or change any other settings.
Step 3: press the Start/Pause button and wait for the machine to empty
any excess water. Press it again immediately after you hear water flowing into
the machine OR two audible clicks. The machine is now in pause mode with the
green light of the Start/Pause button flashing. Only the green light on the Prewash/Wash
button should be on. Leave it in pause mode for 30 minutes and then press the Start/Pause
button to recommence the cycle.
Step 4: If the Start/Pause button begins flashing, water stops flowing
into the machine and the three green lights mentioned above are back on, turn
the Program Selector Dial back to off, wait 10 seconds, and repeat the process
above.
Step 5: If when you then turn the Program Selector Dial to
Whites/Intensive and hear the two audible clicks, immediately press the
Start/Pause button to set the machine in pause mode. Wait 30 minutes. Then
press the Start/Pause button to recommence the cycle.
Hopefully the cycle will run without a problem.
