Apart from doing a power reset, the only thing you can do is call for service. All these machines are controlled by computers and diagnosed by them when the service engineer brings his laptop.
UL means there is too much water in the wash tank. It will continue to run the drain pump u ntill the water level is correct. If it is not pumping out then there could be a problem with the pump, blockage or relay fault on pcb
The display of "BoF" on the display is simply a confirmation code to commence the next operation on the dishwasher. It is not a fault code.
Refer manual of a AMX model Hobart dishwasher. If your model is different the general codes are same.
Most likely switching valve on integral softener. Occasionally it has been the fill solenoid letting by. F04-3 refers in the manual to the wash tank pressure switch, but its actually a fault with water direction. You'll find the switching valve is directing water into the wrong tank, and thisnwillmgive the fault code. Replace softener.
fil massage mean the water not came in the booster tank , maybe the water pressure is low or the solenoid valve is defective, always this massage come to me i change solenoid valve then it will work, check and tell me
press the 1st and third buttons on the display nxt to the start button then press the start button,this will change the the display to something like BOF1 then allow the achine to fill the rinse tank you will know when this has happened as the display will go out (all of it) then you can turn on the machine using the button marked with a I the start button will light red allow it to go green and you are ready to go ... if when you are boffing it it changes to FIL the your water pressure is to low good luc fella
