My HHR radio had poor AM reception no FM reception (after it being fine for the 1 year I have had. Should I take to dealer or would it be better to take somewhere else. There is no warranty.
My radio will not play FM stations at all, AM very poorily, XM fine and CD fine. Should I take it to a dealer to look at or would it be better to take somewhere else?
Although it's about $50, this is the best FM transmitter I've found so far. I use it primarily with my MP3Player, but the concept is the same for your satellite radio. It should have a 1/8" audio plug.
Simply plug this little adapter in your cigarette lighter, plug the 1/8" cable between your Satellite radio and the adapter, and tune your radio to the station on the adapter (you can choose another station if there is already something playing on its default station).
This works for me. I tried other brands and they all eaither had poor reception or died within a month or so. This one has been working for me for well over a year now GOgroove FlexSMART X2 Wireless In Car Bluetooth FM Transmitter with...
Most radio reception problems that occur only while the car is running are caused by damaged diodes in the alternator. It can be difficult to diagnose this since most dealers and repair shops will not disassemble the alternator to test the diodes. If you can find a shop that rebuilds alternators they can test for bad diodes and replace them if necessary. Hope this helps.
you can try a AM/FM antenna booster if you know how to get to the back of the radio. Otherwise the radio ground needs to be checked out and the antenna ground would need to be tested to see if there was corrosion on the antenna base or the connector to the back of the radio. On some cars the antenna is located in bad area and they don't get the signal boost off of the cars ground plane The more reflective surface you have on the car the more radio waves will bounce back and increase signal strength. Also Depending on atmospheric conditions and skip conditions sun spots and other natural occurring things can cause poor reception. The signal booster is about $10.00 at any radio Shack or any auto parts store. Hope this helps.
If the antenna is on the front, pop the hood, and locate where the antenna wire connects to the bottom of the antenna and make sure it is connected well. If everything checks out there, you will have to pull the radio from the dash, and look at the back of it. There will be a large black wire by itself connected to the radio. Push it in to make sure its connected as well. That could really be your only problem unless your radio happens to have a fault on the inside which is extremely rare. Hope that helps
