Sewing Machines Logo
c
carol billington Posted on Sep 21, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I'm looking for manual 1&2 for Elna lotus sp type 35 p836436 the 1968model
! Am looking for manuals 1&2 for this machine
R.A. Ellis
Level 3:
  • Elna Master 12,731 Answers
  • Posted on Sep 21, 2016
R.A. Ellis
Elna Master
Level 3:
Answers
12731
Questions
Helped
2618826
Points
59176
You will probably need to contact an Elna dealer. Elna does not readily make manuals available.
How do you adjust the tension control on an Elna lotus SP
The tension dial is on the front of the machine right above the needle. The higher the number, the tighter the tension is applied to the top thread. HINT: When threading the top thread, ALWAYS RAISE the presser foot throughout the entire threading process. This allows the thread to seat completely in the tension disk. Tension is correct when the top and bobbin threads meet in the middle of the fabric.
Elna Lotus Instruction Booklet
Elna Lotus SP bobbin case repair Removing cotton jam from Elna Sewing...
Elna SP ST SU sewing machine repair tips (I use liquid Tri-Flow Synthetic Lube or silicone spray to loosen parts seized from old oil. Do NOT use WD-40, cooking oil, motor oil...)
2answers
Having trouble replacing the bobbin case
Elna SP ST SU sewing machine repair tips - YouTube
? 2:25
https://www.youtube.com/watch?v=TqrbimZyP1U
Oct 24, 2011 - Uploaded by Absolute Sewing
More Photos on replacing gears and some repair ti... ... I amhaving trouble with my Elna SU 62 skipping stitches when I sew on knits. ... Elna Lotus SP bobbin case repair - Removing a cotton jam from a Elna Sewing machine ...
Amazon.com: Bobbin Case 627569106 - Elna, Janome ...
1helpful
Manual for elna lotus sp
follow this link for free download
http://www.scribd.com/doc/25386753/Elna-Lotus-Sewing-Instruction-Manual Elna Lotus Sewing Instruction Manual
2helpful
I dont have a manual
I have a PDF of this manual for free. Please provide me your email and I can email it.
Thread from the bobbin is not getting looped
If the bobbin case rotates freely it is probable that the pinion gear is broken. Replace the gear, retime machine and voila it works again. Trouble is tough to find the gear anymore good luck it is a good machine and worth the effort
I inherited my mother's Elna Lotus SP sewing machine. She had the sewing guide inside the machine, but not the instruction manual. I need to know how about the bobbin and how to thread?
Hi Jeanne, you might want to check out my tip on early Swiss Elnas,
http://www.fixya.com/support/r10602655-acquired_early_swiss_elna_sewing
it should help you get the Lotus going. Lovely machine. If you are in the USA you may also want to contact White Sewing Center as he may have this manual available for sale or a copy of it. www.whitesewingcenter.com.
Remember to use the Elna 7 hole dished metal bobbins, there are 7 holes on the top, and looks like this11_7_2011_6_23_57_am.jpg
Always wind it and insert it into the machine this way. Don't use any other bobbin. Standard needles 130/705H, flat shank to the back.
Check out my other tip on bobbin winding too, it is important to keep tension onto the thread spool that you are winding thread off as the machine doesn't tension the thread for you. So you need to apply pressure to the top of the thread spool as you wind off, use the curved handle of your scissors on the top of the spool.
Feel free to connect to me and ask if you have any other questions, I have a Lotus TSP at home and its almost identical to the SP. Happy stitching.
2answers
My dad has just bought a second hand elna lotus sp sewing mashine and does not know how to get the spool out can you please help him he said it has type 35 on it
Look in the back. By the lever you will see a white knob on a spring. Pull this down, put it in the bobbin; lift out. This is the bobbin take out method. Hope this helps. Keep this machine. It is great and only increases in value.
4helpful
Manual for Elna lotus sp model 35 m703163
Top Elna Sewing Machines Experts
Mike Cairns
Mike Cairns
SmartAviator
SmartAviator
Ngoro
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
