Canon Ir 3300 B/w Copier image Runner Series Logo
Arunabha Nath Posted on Sep 20, 2016
Download mode cannot initialized?
First time when i start the mechine the bar is complete but image is shwoing wait,,, and next time the touch display is showing e602-0001. what i do????
1 Related Answer
Anonymous
  • 130 Answers
  • Posted on May 30, 2008
SOURCE: SD300 LCD Display Shows Same Image
Sounds like it needs service. Call Canon tech support.
Not being booted
TRY THIS TROUBLESHOOTING: -Removed all external devices connected in the computer -Removed the battery and AC Adapter -Press and hold the power button for 20 seconds -Plugged back in the ac adapter and press again the power button to turn it on -Right after pressing the power button to turn it back on, keep on tapping or pressing the F8 button to go to safe mode -If the system is already in safe mode and do system restore from the previous date before the problem occured then just wait for it till it restart the system
(NOTE: If F8 is not working do this next steps) You can only do this troubleshooting if you're ready to loose all your files saved in the hard drive for it will restore back your computer to its factory settings.
-Turn off the unit completely -Press the small button that is next to the power button (button that has an curved arrow icon) -Wait for it then you'll be prompted with 3 options (One Key Anti-Virus, One Key Recovery, System Setup) -Choose One Key Recovery and click Next -You'll be prompted 2 options (Restore from initial backup and restore from users backup) -Choose Restore from Initial Backup then click on Next or Start then just wait for it to finish the process -After the process was done click on reboot and it will ask you to setup your computer for the first time again just like when you first got the computer -If all else fails you might need to call the Lenovo Support to ask for Recovery disc or for service repair for possible hardware problem. Lenovo Support Hotline - 18774536686 then press option 2.
Just got the Lenovo IdeaPad notebook. I tried to install Office Professional, but it kept failing. I tried to uninstall the Office files, to start fresh and that failed too. Next, I attempted to do...
Welcome to Fixya
Sounds like the Windows is already corrupted. You can try to restore the computer back to the original factory state. Please take note that this will delete everything you got ther inside the computer. Turn off the computer the press the one key button beside the power button. Select the one key recovery then press enter. Select restore from initial back then wait unit the computer will be restored.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
1helpful
Ran the Tshibery disk recovery disk. Completed and
Complete the recovery again but leave the discs in the computer. That way if the computer needs some files while rebooting it will take them off the cd....if not it will load and that will be the end of that. Just remember when you boot the computer for the first time to initiate the recovery, when it says to boot from cd touch any key...that is only done one time when you first initiate the recovery...after that do not touch any key if it says that...just let windows boot on it own. Once windows boots on its own, then you can take the recovery disc out and put it away.
New Konica bizhub C351 copier with only 58 copies. It will make copies but it has a 6 1/8" x 8 5/8" BLACK area in the center of the 8 1/2" x 11" copy if you make a copy from the platen glass. It does not...
Gray box after installation.
Solution
CAUSE: Installation procedures were not completed properly.
SOLUTION: Complete the installation procedures thoroughly:
1. Adjusting Touch Panel - Press the Accessibility key, Touch Panel Adj.
2. Setting Gradation Adjustment - Go into Service Mode, Image Processing Adjustment, Gradation Adjustment. Service mode- ulilty/counter, check details , then(Stop00 stop01)
3. Touch High Compression Mode and press Start [perform 3 times].
4. Touch Gradation Mode and press Start [perform 3 times].
5. Touch Resolution Mode and press Start [perform 3 times].
6. Date/Time Setting - go into Service Mode, Press Stop, 1, 1, 4, 4, Clear.
7. Go into Utility/Counter, Administrator Setting, System Setting, Date/ Time Setting.
8. Install Date - go into Service Mode, System 1, Install Date.
9. Serial Number Input - go into Service Mode, System 1, Serial Number [If Serial Number is already there, Clear and re-enter it].
10. Unit Change - go into Service Mode, System 2, Unit Change.
11. List Output - Please Load 8.5x11 Landscape paper on Tray 1, go into Service Mode, List Output, and Touch Machine Management List and press Start.
12. Press Adjustments List and press Start.
13. Press Service Parameter List and press Start.
14. Press Fax Setting List and press Start.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2answers
E-000602-0003 error is occurring when machine powered on
the error E602 is Hard disk error and you can clear it in
Service Mode and Making Selections
1) Press the User Mode key ‘ ’ .
2) Press ‘2’ and ‘8’ on the keypad at the same time.
3) Press the User Mode key ‘ ’ on the control panel.
In response, the following Initial screen will appear:
To reset the error, execute the following in service mode:
COPIER>FUNCTION>CLEAR>ERR.
else you need to replace your machines hard disk
I want to change my konica sitios 7020 printer to english,its in japanese
Procedure
Touch 1. System Initial on the Key Operator Mode Screen to display the System
Initial Setting Menu Screen.
2 Touch 2. Language to display the Language Selection Screen.
3 Touch ENGLISH, FRENCH, SPANISH, GERMAN, or ITALIAN
Touch OK to complete the setting and return to the System Initial Setting Menu
Screen.
5 Touch RETURN to restore the Key Operator Mode Screen.
6 If no further changes are required, touch RETURN to restore the Basic Screen to
perform copying operations
1997 Nissan Terrano electronic compass blinking
CORRECTION FUNCTIONS OF COMPASS
NAEL0307S01
The direction display is equipped with automatic correction function.
If the direction is not shown correctly, carry out initial correction.
INITIAL CORRECTION PROCEDURE FOR COMPASS
NAEL0307S02
1. Pushing the “Mode” switch for about 10 seconds will enter the
initial correction mode. The direction bar starts blinking.
2. Turn the vehicle slowly in an open, safe place. The initial correction
is completed in one or two turns.
NOTE:
In places where the terrestrial magnetism is extremely disturbed,
the initial correction may start automatically
Convergence problem
This is out of the service manual
don't forget to write the setting to rom by hitting the pip button twice
Good luck and don't hesitate to ask questions
2.12.5 Convergence point adjustment
Adjustment preparation
(1) Select color to adjust.
“STATUS” - Green
“0” - Red
“ANT” - Blue
(2) Use 4, 6, 2, and 5 to move the cursor position
(dotted lines).
(3) Use thumb stick to move the convergence point.
(4) Three adjustment modes are available:
1. (3x3) Press “STATUS” 5 times (only works
when DCU is in uncorrected state)
2. (7x5) Press “0” 5 times
3. (13x9) Press “ANT” 5 times
For touch-up, only the (13x9) mode is necessary.
This will adjust every cross-hatch intersection point
on the screen.
For complete adjustment, start with (3x3) mode. This
will adjust center point and eight edge points only,
but will greatly reduce adjustment time. Then use
(7x5) mode, and finally (13x9) mode to finish
convergence.
If “S” distortion appears between cross-hatch lines
repeat (7x5) mode to change calculation process
while adjusting to remove distortion, then return to
(13x9) mode to finish touch-up convergence.
Adjustment procedure
(1) Receive any NTSC signal.
(2) Start adjustment at the center of the screen.
(3) Continue adjustment at next closest position.
(4) Adjust center area first, ending with edge sections.
(5) Press INFO button to perform calculation operation.
This process will take about 2 seconds and no
picture will be seen at this time.
(6) After interpolation, check convergence again and
repeat (1)-(5) if necessary.
(7) When convergence is acceptable, press PIP MODE
to write data to ROM memory. ROM WRITE? is
displayed to alarm system that ROM will be
overwritten with new data. Press the PIP MODE
button again to write displayed data to ROM.
(8) DATA WRITE TO ROM will take approximately 4
seconds and no picture will be displayed.
(9) Green dots will be displayed when operation is
completed.
(10) Press MUTE to return to convergence pattern, then
confirm again convergence is acceptable.
(11) Press PIP MODE (ROM WRITE) mode, then press
PIP CH to initialize sensor data positions.
(12) Input any 1080I signal.
(13)Press EXIT key 5 times to exit video mode.
(14) Select an input with 1080i signal.
(15)Access menu and select ASPECT 5 mode.
(16)Press the SERVICE SW. ONLY button to enter to
DCU crosshatch signal.
(17)Repeat steps 2~11 above.
Notes: (1) Display only green for easier adjustment and
match to jig screen. Press “MENU”, THEN
PRESS “STATUS”.
(2) Perform interpolation and data write to ROM
after green adjustment. Once green has been
confirmed to match jig screen, the jig screen can
be removed. Do not readjust the green color
after jig screen has been removed. This is now
your reference color.
(3) Display green and red only and match red to
green.
(4) Display all colors and match blue to green and
red. Touch-up red color if necessary.
(5) Existing DATA in ROM can be read by pressing
the SWAP button 2 times. This data can be used
after replacing a component (CRT, DY, etc.)
Where complete convergence adjustment is not
necessary, be careful not to overwrite this data.
DO NOT write cleared RAM data into ROM or a
complete convergence adjustment will be
necessary. Remember to try MAGIC FOCUS
before starting convergence adjustment to
minimize adjustment time.
10helpful
Samsung CLP 510 laser printer
Try this:
There is a hidden maintenance menu in the machine!!!
You can enter the menu in this way:
Start up the machine with push in the buttons "online" and "cancel"
--You will see the message "Download mode press online key"
Press about 15 times the "menu" key
--You will see the message "Uncheck consumable mode"
Press about 15 times "menu" and 5 times "enter"
--You will see "Press access key"
Press a few enters
Press 3 times "cancel"
Go to the EDC mode
-- you will see "press access key"
Press "cancel"
Go to maintenance and initialize the parts you like to reset.
Nice isn't it?
(sometimes you have to try a few times; don't wait to long in between the steps)
old marine
old marine
ZJ Limited
ZJ Limited
