If your washer doesn't agitate,
check these
Lid switch
If the lid switch is defective, the
washing machine may not agitate or function at all. The switch is inside the
washing machine main housing near the door frame. Often you have to raise or
open the top or front of the washing machine to get to the switch. If it's
defective, you need to replace it.
Belts
Many washing machines have one or
two belts. If a belt is broken or badly worn, you need to replace it with a
genuine belt from the manufacturer. (Some washing machine belts are designed
with special characteristics not found in automotive
belts.
Drive motor
Many washer brands use a reversing
motor. For agitation the motor runs in one direction, for spinning and draining,
the other. It's possible for a motor to burn out in one direction and continue
to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys
The motor or transmission drive
pulley may be worn and unable to turn the drive belt. If so, replace the
pulley.
Transmission
The transmission could have either
of these problems:
- The transmission may have a worn or broken gear, or some other internal
problem.
If you suspect a transmission problem, you may have
to call a qualified appliance repair technician to repair
it.
Agitator
The inside of the agitator--where
the transmission shaft attaches--can become worn, and strip out the spline that
allows the agitator to properly grip the shaft. Then the transmission shaft
rotates back and forth as it should, but the agitator doesn't move properly. If
this happens, you may need to replace the agitator and/or the transmission
spline.
