Make sure you are using a brand-new needle and that is installed with the flat side facing the correct direction.
Remove the upper thread from the machine. ALWAYS RAISE the presser foot and rethread the upper thread. Verify the thread path is correct. Set the thread tension at the midway point between high & low number.
Lower the presser foot, retest the stitch quality on scrap fabric and adjust the upper thread tension until the upper thread and bobbin thread meet in the middle of the fabric.
Sewing Machine Thread Bunching Up Here Why
Understanding Thread Tension Threads
SOURCE: cotton breaking when sewing into thicker material
Try a different needle, matched to the weight of your fabric.
SOURCE: cotton keeps getting knotted from the bobbin
upper tension is wrong or upper threading is wrong (problem is always on the other side of the bunched thread)
SOURCE: i have a RS2000 and
I think you are suposed to use the left hand guide above the needle. The right hand guide is used when you are using a twin needle. See if that helps.
SOURCE: the cotton on my bernina 801 keeps jamming
Loops on bottom indicate a top thread tension problem.
Make sure needle is the correct size and not bent or broken
Make sure it is threaded properly with the lever UP.
Do a test stitch.
If it still loops below... tighten the top tension and do another test stitch... keep doing this until the stitch is balanced.
BTW... always grasp and hold both threads when starting a seam.
