Washing Machines Logo
Kevin Ives Posted on Sep 17, 2016
My beko wm5120w washing machine would not spin. now it fills but wont start start wash cycle, all it does is clicks.belt is ok, door switch seems ok and i can get it to drain but that is all?
Danny Sk
Level 1:
Habit-Forming:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 9 Answers
  • Posted on May 14, 2020
Danny Sk
Contributor
Level 1:
Habit-Forming:
Welcome Back:
Answers
9
Questions
0
Helped
13909
Points
29
If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. https://9apps.ooo/download/
William Goodman
Level 1:
Habit-Forming:
New Friend:
  • Contributor 42 Answers
  • Posted on Oct 25, 2016
William Goodman
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
42
Questions
Helped
14889
Points
91
Unplug from wall check contacts at motor and pcb/ timer plug back in see if that works motor pulls a lot of juice look for a burnt contacts or connections. motor may be thermally fused .dont just bypass find the reason why thermal fuse failed
5 Related Answers
gittos73
peter gittos
  • 247 Answers
  • Posted on Sep 12, 2007
SOURCE: Washing machine does not drain
does the water pour out when you put the drain hose close to the ground if it does then make sure your pump isnt blocked if it isnt then youll need to replace the pump most pumps have 3 little fins in them if you can stop those fins with a screw driver when pump is going then it deffinatley needs replacing as you cannot fix them sorry for the bad news m8
Anonymous
  • 1073 Answers
  • Posted on May 01, 2008
SOURCE: washing machine not draining and spinning
check the lid switch
Anonymous
  • Posted on Sep 04, 2008
SOURCE: GE washing machine, wont spin
Same problem (but without any smell). You should try to reset the two computer boards in the washer. You do this by 1) unplugging machine and wait for 30 secs; 2) plug in machine; and 3) open and fully close the lid at least 5 times. This resets computer boards, which can get messed up by power surges, etc.
Neciforo Llanto
  • 942 Answers
  • Posted on Jan 30, 2010
SOURCE: washing machine drains, wont spin, making clicking
If your washer won't spin, check these: It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Anonymous
  • 12 Answers
  • Posted on Jan 20, 2011
SOURCE: My Beko washing machine switches
sounds like circuit board is faulty
1helpful
My front load washing machine agitate but won't spin
If your machine is rather old or used quite frequently, you should check out the motor brushes. Go to youtube for details on washing machines brushes.
2answers
My washing machine wont spin
Hi if your Beko Wm & Wma Models washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
2answers
Washing machine fills with water but then won't wash, spin or drain
Hi Claire if your beko washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
2helpful
How to reset beko wm5120w washing machine
You need to get the dial to 90 degree program then push the start and on button together. Keep hold the start button then a light will flash. Then move the dial to spin/drain option and press start to start the reset test mode. Hope this helps.
1helpful
1helpful
Beko WM5120W Washing Machine
Sludge from doorseal.
Renew doorseal
BEKO WASHING MACHINE WM5120W WONT START!!!
first off let me say u may have a motor with bad windings. if it is belt drive try removing the belt and see it after plugging in and starting , will it now run? thus weak windings. you may have a bad control board but first check these
WASHER WILL NOT START:
Power If your washing machine won't start, begin by looking at the power source. First of all, is the washing machine plugged in? If it is, has it tripped a circuit breaker or blown a fuse? Check and reset the breaker (or replace the fuse) if necessary.
Lid Switch The main control for the washing machine is the switch inside the lid. If this has stopped working for some reason, your washing machine won't start. It's not especially difficult to troubleshoot this on a washing machine. You might have to open the top to access the switch. With the power on, depress the switch and listen for a click. If you don't hear one, the switch MAY BE BAD and will need to be replaced. Confirm defectiveness with a multi meter checking for continuity OHMS. An open circuit reflects a bad switch..
If the switch works but the washing machine still won't start, check to see if your washing machine has a special fuse for the lid switch. It will usually be inside the control panel. If it's blown, you'll need to replace it before the washing machine will start.
Door Interlock The problem could be with the door interlock. If the lights come on but the machine won't start, this might well be the cause. This could either be down to the wiring that runs to the door interlock, or the door catch not activating the interlock itself.
Timer Knob Some models of washing machine use a mechanical timer knob and won't run until the water in the machine has filled to the selected level. If the knob doesn't line up properly with the graphics on the control panel, you can try to troubleshoot the washing machine problem by advancing the timer a little. When you've done this, pull it out a little way and see if the washing machine will start properly.
Push start switch may need to be tested with a multi meter for continuity OHMS should show a closed circuit when pushed in or turned on.
The start switch on some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in
Overheating If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings.
By the way my advice is free cuz God is good!
All washing machines use a motor that is responsible for spinning and agitating during the cleaning cycle. Many top load brands use a reversing motor which means the motor spins in one direction for agitating and another for spinning and draining. If the motor does not start, but makes a humming or buzzing noise then it may be defective. To verify if the motor is at fault, remove the drive and /or pump belts and then try to start the motor again. On direct drive models, you will have to disengage the pump and the direct drive coupling to the transmission. If the motor starts, then the problem is with the transmission or the pump and can be further diagnosed by reconnecting each one individually. If the motor does not start or continues to hum or buzz, then it will need to be replaced
Lastly CONTROL BOARD
If the control board does not provide the proper voltage to the drive motor, fill valve, drain motor or door lock then the washer may not start. The main control board on most washers is complicated and difficult to diagnose without proper test equipment and procedures. You can visually inspect the control for signs of electrical arcing or burned or damaged components on the board. You should use caution when replacing a control board as sometimes the burned components are caused by external component failures.
https://www.repairclinic.com/RepairHelp/Washing-Machine-Repair-Help
http://www.partselect.com/Repair/Washer/Will-Not-Start/
Washing Machine Repair Help http://www.partselect.com/Repair/Washer/Will-Not-Start
Hello, I have a beko WM5120W Washing Machine, and when I try to use the quick wash programme, it does the washing cycle ok, but when it starts the rinse programme, it pumps the water out ok, but when water...
hi
the water level switch or sensor does not activate to tell the programmer that there is plenty water so that it can start to rinse ( what you doing is simply overriding the system .
Top Beko Washing Machines Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
