My Bosch dishwasher has an e14 error code. It also says check the water supply. I have checked the filters at both ends of the hose and these are not blocked. Is there anything else you can suggest.
Hey Karen, Water in the bottom of the dishwasher results from clogs in the filter or in the drain hose. Before you do any work on your dishwasher, make sure that it's switched off at the mains. If cleaning your filter hasn't resolved the issue, then the next thing that could be preventing your dishwasher from draining is a blocked drain hose. Is your dishwasher displaying an error code? If you see the E25 error code on a Bosch dishwasher, that means the filter is blocked or clogged, and water cannot drain out of the machine correctly. You can check all Bosch dishwasher codes here: https://www.justfixed.co.uk/bosch-dishwasher-error-codes/
Hi Jane, water in the bottom of the dishwasher results from clogs in the filter or in the drain hose. Please make sure that you have disconnected the appliance from the mains before cleaning the filter! If your dishwasher is displaying an error code please check the meaning of the error message.
It means that water is not getting to the dishwasher. Make sure your water valve is turned on all the way. If that's okay, then maybe your water supply hose got kinked when you pushed the dishwasher back in it's place. As a final check, turn off the water, disconnect the water supply hose at the dishwasher, and with the end of the hose sticking in a tall bucket, turn the water valve back on. You should have a good strong flow. If not, then your water valve (under the sink) is bad, and you will probably need to call a plumber, because the problem is not in your dishwasher.
hi julia
after checking on your bosch water heater error code e14
you can try to reboot your system but if code comes back you may need to find a plumber that knows your system to fix your fan system and clear your fault code. this is the site i got info from http://www.jimsplumbing.net.au/bosch-hot-water-system/troubleshooting-guide/error-code-e14/
p.s. this site is not in the usa
Hi Darlene, The link below is a bosh dishwasher error code AND how to fix, I hope this helped..........CHEERS.. Bosch Dishwasher Error Code E22
Fault Condition: Residual water in sump
Repair or Check: Check for a blocked pump, a dirty filter, or grease build up.
Parts Required: Pump or clean filter
Hi Gilgol, The link below is a Bosh Dishwasher list of error codes, I believe your error code is E3....CHEERS.. http://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/ Bosch Dishwasher Error Code E3
Fault Condition: Not filling with water
Repair or Check: If the water supply cut-off valve on the dishwasher is completely open but the dishwasher will not fill with water then shut off the water supply and unplug the dishwasher. Remove the water fill line and check to see if the water inlet screen valve is plugged up. If so then replace the water valve. Cleaning the screen can make the issue worse so always replace if the screen is clogged. The valve can get stuck open from gunk and therefore flood or overfill.
Parts Required: Water inlet valve Bosch Water Inlet Valve Assembly for Dishwasher
What brand dishwasher? Model number might help too.
If it is a Bosch this might be the answer.
The E15 fault code means that the dishwasher is not receiving water through the water supply hose, or at least that what the machine thinks anyway.
E15= Check Water Inlet supply*
This can be caused by several reasons.
1. The filters in your inlet hose or inlet valve are blocked and need cleaning.
2. The inlet water supply valve is faulty and worn out, not allowing water in fast enough in relation to the set amount of time it takes to fill the machine for washing etc..
3. The water supply isnt turned on fully underneath the sink?
You will need to undo the water inlet hose from under the sink and check to see if there is a filter in that end of the hose and check to see if it needs cleaning. It will be of the wire Gauss type.
If not, then you will need to uninstall the dishwasher and pull it out from the cabinet to check the inlet valve where the inlet hose connects to at the bottom rear of the machine.
The valve itself will have a filter, where the hose attaches to. Undo the hose and visually check the filter in the valve for blockage/restrictions.
If the above brings no results, then you probably need a new inlet valve for the dishwasher.
