It sounds like there may be an issue with the balance of your washer. When a washer is out of balance, it can spin violently and cause the machine to reset. Here are a few things you can try:
- Make sure the washer is level: Use a spirit level to check if the washer is level. If it is not, adjust the legs until it is.
- Distribute the load evenly: Make sure the load inside the washer is distributed evenly. This will help to keep the washer balanced during the spin cycle.
- Check for foreign objects: Make sure there are no foreign objects in the drum or the drum's seal, which may cause the washer to vibrate.
- Check the suspension: Inspect the suspension system, which supports the drum and keeps it in balance. If the suspension is damaged or worn out, it will need to be replaced.
If the problem persists, it's best to contact the manufacturer or a professional technician for further assistance.
