Question about Pride Jazzy 1103 Ultra Standard Power Chair
Jazzy 1103 Ultra sets speed to slowest when cold
After sitting in cold weather for a couple minutes, the speed setting will change to the slowest by itself. Does not seem to happen indoors, or in warm weather. Chair usually operates normally.
5 Suggested Answers
6ya staff
SOURCE:
lennieg2000
  • 692 Answers
SOURCE: I just gave my mother
tam The batteries need to be replaced. With the lights flashing indicating low voltage and the chair just creeping means weak batteries. With a donated chair you do not know how long the chair sat without being charged. You need to purchase 2 U1 batteries. If there is a battery warehouse store near you or an Interstate battery store check with them because your cost will be less than going through a provider. Hope this helps you
Posted on Sep 26, 2010
HoverTech
Donna Angelo
  • 232 Answers
SOURCE: Re: Pride Jazzy 1103 Ultra.
When the power seat lift lowers down, there is usually a bracket that pushes a button under the seat that tells the motor the seat is lowered and the power chair is safe to operate. Sometimes the bracket can get bent and the button does not get pressed when the seat goes down. Check under the seat around the seat post for the button and make sure the bracket is connecting to it. Carefully bend it back into place if it is not hitting the button properly. If the bracket came off, it will need to be replaced.
Posted on Oct 20, 2010
Dave
  • 27 Answers
SOURCE: y mom's jazzy 1103 ultra will not operate .
Those blinking battery level LED's are showing a trouble code. Count them ("all of them" is the wrong answer). Then refer to this page:
Pride Mobility Products Corp Basic Troubleshooting Instructions
I know the 1103 isn't on the list, but all the Pride chairs use the same codes. Try the 1107 guide.
Posted on Dec 24, 2014
wcdoc1953
wcdoc1953
  • 280 Answers
SOURCE: Previous owner had to have speed adjusted all the way down on my pride mobility jazzy 1103 ultra chair. How do i turn the speed back up
You would need a hand held programmer to adjust the controller settings. The least expensive route short of purchasing a programmer is to bring the power chair into a local dealer to get it programmed. Hope this helps.
Posted on Apr 04, 2016
Apr 04, 2016 | Pride Health & Beauty
How do you replace battery in Jazzy 1103
take the seat off and take off the cover over the batterys and then
write down diagram of current wires on batterys and then change batterys and return cabes as to your wring diagram and reverse the first steps
Nov 22, 2013 | Pride Jazzy 1103 Ultra Indoor Power...
How can i govern the speed on a jazzy 1103
The joy stick can be reprogrammed by a mobility service center. You can't to this by yourself. It takes special tools to do it.
Mar 04, 2013 | Pride Jazzy 1103 Ultra Indoor Power...
My brother who died about 2 years ago left a jazzy 1103 ultra mobility chair. Unfortunatley I cannot work out how to start it. Its all charged but can't find ingnition. Can you help please Anne ...
ana at the top of the joystick is the on/off button just push it and the lights sshould come on the battery level lights should all light up and you can set the speed with the two buttons on each side the left to slow down and the right to speed up. When all the speed lights are lit you are at max speed Hope this helps
Apr 19, 2011 | Pride Jazzy 1103 Ultra Standard Power...
I have changed out the batteries and hand control on my Jazzy 1103 Ultra.but now the circuit breaker keeps tripping. Dee
Donna sounds like the wiring could be the problem. Did you change the batteries? Does the joystick light up when you turn the chair on? Or does the breaker pop when you try to turn the chair on? Give me as much info as you can as to what you are doing when the breaker pops thanks
Jan 31, 2011 | Pride Jazzy 1103 Ultra Standard Power...
The battery light flashes and the chair wont go.
Sounds like it might be time to change the batteries. Even if batteries are charged correctly they eventually lose power with use and need to be changed. Here is a link to the battery needed for the Jazzy 1103 Ultra http://www.replacementupsbattery.com/UB12350-NB.html
Oct 31, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Y mom's jazzy 1103 ultra will not operate .
Make sure motors are in gear. Unplug from wall then try to turn on.
Jun 26, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Had new batteries and a service 6 months ago. Has now been left standing for a couple of months. I charged it up last night, but nothing. The charger appears to be working, lights working. Any ideas
Yes your batteries have dropped below 9 vlt each and they wont chage using your charger. Yuo must take a car battery charger and charge each battery up to at least 11vlts for your charger to charge! This ought to work if batteries have only been sitting a couple of mths . When using a car charger set charge at 6-10 amps for about 45mins to 1hr then hook up chair charger and you should be ok
Feb 21, 2010 | Pride Jazzy 1103 Ultra Standard Power...
I need the pinout of the jazzy 1103 ultra battery
The Output voltage 24 - 29v ,Usually 27v. (And 4 Amps)
The Pin arrangement is Negative to the Left, Inhibit in the Middle, And Positive to the Right Assuming your looking into the plug itself from the front.
Always check with a Voltmeter first though because there are some chargers with the Opposite Pin Arrangement.
Dec 11, 2009 | Pride Jazzy 1103 Ultra Standard Power...
Pride Jazzy 1103 Ultra Standard Power Chair  Logo
217 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
