SOURCE: Kohler whirlpool 5' tub
Here is the link to the Kohler 1209-LA jets exploded view:
Kohler 1209-LA
Hope this helps!
SOURCE: When we press the
Remove the GFCI WALL OUTLET and try connecting those wires together blk/blk..wht 2 wht...ground to ground and then see if tub will stay on, if not suggest put back together and call qulified whirl pool tech to find short in pump motor.
Please rate. Thank you. jj505
SOURCE: Kohler Whirlpool tub motor wont turn on
Kohler Whirlpool tub turns on and shuts right off. Reset gfi and motor turns on and shuts right off. Help
SOURCE: The air pressure switch is bad, motor is still
Check for an air switch at your local hot tub store
take the old one in so they can match it up to a new one
SOURCE: kohler bath whirlpool turns off after 1 second
When you say turns off, is it tripping the safety circuit?
