SOURCE: fabric softner dispenser
Start by cleaning the dispener, pull the dispenser out the owner manual should show you how to do this.
Take the cover off and clean and rinse the dispenser out, reassemble.
If this doesnt help let me know, there may be other problems.
SOURCE: Kelvinator or (Speed Queen Top Load washing machine)
I have a Speed Queen AWM373W top loader with the same problem. We recently had the kit and belt replaced because it was leaking water. That is fixed now but it takes forever. The other night I tutned the drum by hand and it worked fine. Did not had the same problem since but I am watching it.
SOURCE: SPEED QUEEN WASHING MACHINE LEAKS WATER WHEN IT STARTS WITH WASHU
check hoses and pump area.
SOURCE: My speed queen top loader is leaking water during
It is probably the pump. Run the washer with the front off of it. The pump is on the bottom of the motor.
Easy repair.
SOURCE: Replace Water Pump on Speed Queen Washer
did you look at the front panel if you tip the machine to the back and look at the bottom of the panel you will see 2 hex head screws remove them and lift the panel out and slide it down some machines others you have to remove the top
