New ink cartridge stuck in carriage causing a jam. Not paper jam have checked everything.
SOURCE: Printer shows Carriage Jam, but I can't find it.
Push cartri9age to left about a 1/4", with finger pressure. Un-jammed my printer.
SOURCE: Error message: Open door, clear carriage jam and then press enter
Our support works this way. You will receive an email notifying you that there has been a reply to your post, such as this. You read the post, enter your comments in the Comment Text Area Below and you'll get another email when there is another reply.
I will ask you to do one thing, await your response and then give you further instructions.
First of all, with the printer on, and leaving it on, open the cover to the print carriage area. Now, reach over to the right under the cover of the printer and pull the ink carriage to the center.
You will want to use a flashlight to examine the area around the carriage bar for an obstruction. Common items are pencils, pens, paper clips. Additionally, the ink cartridges themselves may not be firmly locked down in place. You may notice this when you reach under and over to grab a hold of them and drag them over to the center.
Should you be able to get this carriage over to the center, check that the cartridges are lock down and nothing is lying in their path on the far right hand side. A flashlight will help you.
Regards,
Worldvet
SOURCE: Carriage Jam - HP Officejet J3680 All-in-One
the silver bar the carrige slides on has lost all its lubrication. Try putting some chapstick on the silver bar
I’m happy to assist further over the phone at https://www.6ya.com/expert/dan_91204789c5bd4b93
Testimonial: "You are a brilliant god-like person!! THANK YOU SO MUCH!!!!"
