Panasonic KX-TGA101S Cordless Handset Logo
Posted on Sep 14, 2016
Phone doesn't receive or make calls. display says "1 missed call" and I can't access any other functions.
How do I get voicemail of a Samsung s6 phone .
Samsung Galaxy S6: How to get voicemail (phone calls go direct to voicemail)
Hello.. 2 things we need to address here:
1. How to access voice mail account:
Access VM: Press 1:
Easy way to access your voice message system is to go to the dialer pad on your phone and press down on the "1" key until your voice messaging system announces
or you can dial your phone number to get to your voice mail
2. Change Call Setting, go to:
Dialer > (3 dots) Select Settings > Call > (scroll down) Select More Settings > Call Forwarding > Voice Call > then change to Always Forward (turn off)
I have a nokia 7610.when i turn it on, i can only see the white display.i even changed the display.
If changing the Display doesn't help and the phone functions without any issue, then the problem could be related to your phone Display IC. When the Display IC is bad, only the light will be displayed instead of the Pictures or graphics. To fix this issue, you'll need a mobile repair technician so that he/she could check the issue. Please understand that this isn't a task for non-technical guy, in case the handset if opened or repaired without proper knowledge or experience, it could bring permanent damage.
But if in case the phone doesn't work when the display is white eg. No calls can be received, or no messages could be received, then it could also be a problem with the phone software. The same problem could only be fixed by flashing or upgrading the phone software.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
2answers
How I access Missed Calls?
Please repost your question and include the name of the manufacturer and the model of your router. Just post again and include this for us.
Thanks!!
EJ
Apr 08, 2011 • Cell Phones
Hello, I am having Nokia N-72 and from last two days it is not displaying missed call(eg. 1 missed call) and msg(1 msg received) on screen. plz help in solving this asap.
That show you have missed calls and messages on your phone so you have to click on the messages like wise calls to check the missed calls and messages you have on your phone
Feb 11, 2011 • Cell Phones
1helpful
Dialled calls,missed calls and recieved calls
hi,
in my phone dialed, received and missed call data are not saved. all data vanished and it shows empty always
Missing Calls and Texts. Alarm Caput.
Cause:-
Call logging is not enabled for the Message list.
Ensure call logging is enabled from the Phone application Options menu.
1) From the Home screen, open the Phone application.
2) Display the menu and select Options.
3) Select Call Logging.
4) In the Show these call log types in message list field, select the type of call log to be displayed in the messages list.
5) Display the menu and select Save.
I hope I was able to help you.
2helpful
How can I turn the ringer back on? Thank you
1 Press (MUTE/FUNCTION).
2 Scroll to “Ringer setting” by
pressing öor ñ, and press á.
3 Press áat “Ringer volume”.
4 Select the desired volume by
pressing öor ñ.
•Each time you press öor ñ, the
volume will change and ring.
To turn the ringer OFF:
press örepeatedly until “Off ?” is
displayed.
5 Press á(Save key).
•A beep sounds.
To turn the ringer ON:
Press ñin step 4.
•The ringer will sound at the LOW level.
•You can exit the programming mode any time by pressing (OFF).
•If set to OFF, “Ringer off” will be displayed while the handset is not in use.
•If you have received new calls, “Ringer off” will not be displayed but
“Received calls” will be displayed while the handset is not in use.
“Ringer off” will be displayed for about 5 seconds after completing operations
or lifting the handset from the base unit or the charger.
•You can also select the ringer volume while an external call is being received.
Press öor ñwhile the handset is just ringing.
•You can change the ringer tone for external calls. See page 49.
HIGH
MEDIUM
OFF
Ringer volume
Low High
Ringer volume
Off ?
LOW
ñ
ñ
ñ
ö
ö
ö
V.M. access
HRinger setting
Initial set
HRinger volume
Ringer tone
18
LCD
I WANT TO KNOW TOTAL CALL TIME IN W580i
When on the home screen the left soft key takes you to your call history. This is divided into tabs, with the first default tab showing all calls and the other tabs showing incoming, outgoing, and missed calls. Each tab shows a chronological list of calls, displaying the phone number dialed. The currently selected item also shows the date and time of the call. The left soft key is assigned to call the currently highlighted item, while the right soft key opens a menu that provides additional functions. Data counters can be found in the phone settings, as well as total call timers and a message counter.
se_w580i_callhistory.jpg During a call the right soft key is assigned to end the call and the left soft key opens a menu with additional options. These options include the ability to turn the speaker phone on and off, add a call for conference calling, place the call on hold, or enable the mute function. The W580i also supports multi-tasking, so you can access other phone functions like your calendar and contacts while on a call. We found the call management feature set on the W580i to be fairly standard, with nothing that stands out, but nothing important missing, either.
Understanding and changing the display
it could be missed call just see ur missed calls
May 17, 2008 • Cell Phones
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
