Timex Sport Ironman Indigo Watch - Blue/b Lack Logo
Remove back of timex indigo watch - Timex Sport Ironman Indigo Watch - Blue/b Lack
1helpful
How to make my Timex indigo WR30M expansion band smaller it diesnt have pins ti remove in order to take out links
there is a method to do this but it takes a watch maker or jeweller to do the job
Take it in and have it adjusted
3answers
Indigo light doesn't work
It is possible that either that the movement of the watch is not aligned properly after a battery replacement.
I NEED A TIMEX INDIGO WR 30M WATCH MANUAL
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
3helpful
Condensation on inside of face, how do I stop it from happening? and how did it get there in the first place? Watch is less than a year old, Timex indigo WR 30M
mcdevito75, Some watches are waterproof, shockproof, and so on. But, no watch is air proof, Believe it or not air is always in your watch and---all air contains water, hot air, cold air, Heat up air and you seperate the water, the air in your watch gets hot on your wrist then cools when you go outside or when you take off the watch. The condensation you see is the tempersture change of the air in your Timex, Believe it or not. It really can"t be stopped, If you can or have a small watch repir shop remove the back and put in another seal around the back cover this should help. Try to keep your watch at a constant temp.
4helpful
How to set the alarm for the Timex Expedition indigo T47852?
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals. Rate me, plz.
1helpful
Indigo light is not working properly, battery needed?
Timex suggests that you have a watch repair person change your watch batteries. I think it would be a good idea to try and replace the battery, but if that fails to work, contact Timex for advice. If they suggest that you should replace the entire wath, keep the battery. I have no guarantee that any of that would work, though.
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
