Cameras Logo
Mary Jackson Posted on Sep 12, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need a Kodak SD Memory Card for Model V570 Serial #KCKFJ 60601263
Need a SD Memory Card
Tony Parsons
Level 3:
  • Kodak Master 6,405 Answers
  • Posted on Sep 12, 2016
Tony Parsons
Kodak Master
Level 3:
Answers
6405
Questions
Helped
1650340
Points
20272
Check manual for correct specs, then order from Ebay
2answers
CAN I USE THE 32GB GO SDHC CARD FOR MY CAMERA KODAK DX7630 CAMERA
No, SD Cards only. Page 53 of the manual.
https://kodakmanual.com/kodak-easyshare-dx7630-manual/
and
I have a Kodak EasyShare DX7630. I bought two new SD ...
JustAnswer https://www.justanswer.com > Electronics Question
Mar 5, 2020 - Your old camera model DX7630 only supports SD memory card type, which has size of 2GB or less. Your camera does not support SDHC card type ( ...
1 answer · Top answer: Hi, I'm sorry about your camera issue. I'm glad to assist you today. Did you purchase new ...
ZDNet https://www.zdnet.com > product > kodak-easyshare-d...
The camera includes an SD memory card slot located next to the battery compartment. The purchase of a 128MB or greater SD memory card when you buy the camera is ...
Pros and cons: Picture quality is excellent ? Battery life is excellent ? Easy to use menus ? View full list
1helpful
Easyshare V570 wont format 32gb card
Strangely, the manual doesn't tell you the maximum size for the SD Card!
https://www.manualslib.com/manual/89337/Kodak-Easyshare-V570.html?page=10#manual
8GB is the maximum spec according to this page and they say
All Kodak EasyShare V Series V570 (8451676) camera memory is guaranteed compatible (pretested in your particular camera), covered by lifetime warranty!
Kodak EasyShare V V570 (V570) Memory Cards - MemoryC
https://www.memoryc.com > kodak-camera-easyshare-v-s...
2GB SD Secure Digital memory card · Suitable for digital cameras, camcorders and more · Designed for older devices with max 2GB SD card support · Lifetime ..
Mar 02, 2023 • Cameras
1helpful
How do I format a SD card in aKodak V570 digital camera
Make sure you have an SD card. If your card is 4GB or larger then it's actually an SDHC card and won't work in your camera.
How do i switch photos from internal memory to a memory card
Hello and Welcome to Fixya!
To switch the photos
from internal memory to a memory card follow the given steps:-
  • Insert an SD card into your Kodak V570 camera.
  • Press the "Review" button on the back of the camera and navigate to the photo you would like to copy, then press the camera's "Menu" button.
  • Select "Copy" from the available options and then press the 'OK" button on the back of the camera. Navigate through the available options by using the arrow keys on the back of your camera.Select "Picture" from the list of options that appears to transfer just one picture. Select "All" from the list of options to transfer all of the photos from your camera's internal memory to an SD card.
I hope this solution helps you
For Further assistance, I am here to help
Thank you and Keep Visiting FixYa
3helpful
Memory card requires formatting error but won't format when select continue
Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards. It is often difficult to find out the maximum capacity a camera will use, as today's memory cards are much larger that those available when the manual for the camera was written.
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible
What memory card do I buy for my Kodak easyshare C530 camera.l The one I purchased was a SD card and it would not allow me to format.
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=7551/7269&pq-locale=en_US&expression=sd
The above link goes to a site that describes how SD or SDHC cards can be used in newer C cameras such as yours.
Also, the following should be noted regarding sd cards:
Question : Why doesn't my camera recognize the SECURE DIGITAL (SD) or MultiMedia (MMC) memory card that is in the camera? Answer : Your camera may not recognize the memory card inside for one of the following reasons:
  • The card is not fully inserted in the camera. Turn off the camera, insert a card into the slot, then push to seat it.
  • The card may be corrupted. Reformat the memory card.
    CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
  • The card may not be a certified SD or MMC card. Purchase a certified SD or MMC memory card.
See your camera's user manuals for more information. Go to KODAK Product Manuals, and select the manuals you need.
1helpful
Kodak easyshare m360 says memory full after 3 photos i just bought the camera, what i shell do < shell i buy memory card or usb for it ?
You need to switch the camera over to saving pictures directly onto the SD card.
  • Menu
  • Cam settings
  • Chose AUTO or SD card option
  • Press OK to SD card
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Once you have set the settings to save onto the SD card directly you might like to transferre your existing pictures from the internal memory onto the SD card:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • 2helpful
    I put a new memory card in our Kodak EasyShare
    Your camera is only supporting SD/MMC Cards (up to 1 GB)
    The card that you currently have might be faulty. Please try another card.
    You might also need to switch the camera over to saving pictures directly onto the SD card.
    1: Menu 2: Cam settings 3: Chose AUTO or SD card option Press OK
    I bought a 2GB SD card for my Kodak EasyShare C330 Camera
    Buy a 1GB card (or 2). The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
    Click
    1helpful
    Cannot locate info. on what SD Cards I can use in my Kodak CD40
    According to the specifications, there is no flash memory card slot in this model. The only way to transfer pictures is via serial cable to your computer.
    Top Kodak Cameras Experts
    ZJ Limited
    ZJ Limited
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
